2nd Gen Legacy Headlight/Turn Signal ?
2 replies to this topic
#1 zooandbio4me
zooandbio4me
    New User
  • Pip
  • 5 posts
  • Ogden, UT
Posted 27 September 2010 - 05:16 PM
Posting in the wanteds for RH turn signal/corner markers for my 98 leg gt sedan. My question is: Will the headlights that have the turn signal/corner marker built in fit/mount into my leg that has the headlight and corner marker seperate? I've seen the headlight/corner in good shape at local yards, just didn't want to buy one to find out wouldn't work. Really seems like it would... anyone know?
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 28 September 2010 - 11:23 AM
I would think as long as it's second gen, 95-99 it should work. However there may be a mid-gen change that might not allow it.
Hopefully someone else with direct experience will chime in.
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,936 posts
  • Charlottesburg, VA
Posted 28 September 2010 - 09:36 PM
I was 40 bucks short of buying a set of the two piece headlights and corner lights off of a 99 outback in the yard last time I went. I had the idea that the newer lights might fit my car, which has the one piece lights, with some slight modification, if any. Just didn't have the cash at the time. Not sure when I'll end up back down there and by then they might be gone. The bodywork around them is the same, the only tings I could see that might be different were the mounting points, and maybe part of the header panel. But the thin metal right around the back of the light housings can be trimmed/cut easily and will not harm anything structurally.
