no horn, no cruise, and ABS light on
10 replies to this topic
#1 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 08 October 2010 - 07:28 AM
97 GT, 2,2L swap, auto w/ 150k miles.
the hor, cruise control quit working and i have an ABS light on all the time. i expected a fuse, but these things are on different fuses and i have check them all.
what do they have in common, the steering wheel?
suggestions?
#2 OB99W
OB99W
    Elite Master of the Subaru
  • 3,315 posts
  • Ithaca
Posted 08 October 2010 - 08:51 AM
John, start by rechecking fuses, specifically #18 in the interior fuse box (10A, center one in bottom row). It's common to the ABS and cruise control modules.
The roll spring is common to the cruise and horn.
Theory: I wonder if a problem in the steering wheel might have taken out that fuse.
#3 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 08 October 2010 - 09:26 AM
will do , thanks
i have never pulled a steering wheel, i'm hoping i don't have to, but we'll see.
#4 OB99W
OB99W
  • 3,315 posts
  • Ithaca
Posted 08 October 2010 - 10:01 AM
I meant to say "clock spring/roll connector", not "roll spring"
I need more sleep. :)
#5 Rooster2
Rooster2
    Subaru Master
  • 4,687 posts
  • Indianapolis
Posted 08 October 2010 - 12:28 PM
will do , thanks
Insert a new fuse in the holder, even though the existing fuse does not look blown. I have had the spades on a fuse or in the holder get dirty, and cause a bad connection to the fuse. I used a sliver of emery board to clean the fuse holder insert portion, as well as to clean the spades on a fuse. This did fix my problem.
You don't even want to think about pulling the steering wheel, but If you have to, be sure to learn all there is know about how to disconnect the steering wheel air bag. You do not want the air bag to blow up, while working on the steering wheel.
#6 bstone
bstone
    Certified Subaru Nut
  • 895 posts
  • Great Midwest, USA
Posted 08 October 2010 - 01:02 PM
Get test light. Check fuses.
#7 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 08 October 2010 - 01:17 PM
so i will be not the guy who swears "the fuses are good, i checked them" i will check them again. but to have a bad fuse after my method of checking fuses would require 2 bad fuses in a row, or a bad fuse seat.
i start with a spare fuse that looks good. when i pull a fuse i replace it with the spare. if nothing changes i move on to the next, pull it and install the one i pulled from the first . keep doing this until i have covered all of the fuses of that size. on to the next size. the fuses that kill something when pulled are obviously good. the ones that do nothing may need further checking. i guess a test light would come in handy.
but i'll check again. i have read too many posts where the cause is a bad fuse after checking all the fuses.
Edited by johnceggleston, 08 October 2010 - 01:21 PM.
#8 bstone
bstone
  • 895 posts
Posted 08 October 2010 - 02:09 PM
That's a labor intensive way of checking fuses. Just get a test light. They sell them at AutoZone real cheap.
#9 OB99W
OB99W
  • 3,315 posts
  • Ithaca
Posted 08 October 2010 - 03:28 PM
If all the ABS-related fuses are good, then I'd suggest reading the ABS code(s).
In general, a continuity tester could prove useful.
#10 wtdash
wtdash
    Subaru Nut
  • 1,564 posts
  • N. ID
Posted 08 October 2010 - 03:57 PM
99.9% sure it's the roll-connector/ clockspring...same EXACT symptons on my '98 Forester - no Horn/Cruise/ABS light on.
Replaced the CS and back in business.
Pulling the steering wheel isn't that tough...getting the damn airbag connectors apart and fishing the harness wires out was a PITA though.
You'll have no problem w/it.
Couple of links for reference #1 and #2....may have to register (free) to see all the pics.
GL,
TD
Edited by wtdash, 08 October 2010 - 03:59 PM.
#11 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 08 October 2010 - 04:50 PM
GL,
TD
thanks td, just what i needed.
