Dirk Posted October 9, 2010 Share Posted October 9, 2010 I was wondering if there is a way to channel air into a carburetor by using some sort of air scoop. Could this be done without channeling bugs and bad weather in there too? would it help increase engine power? cheers Dirk. Quote Link to comment Share on other sites More sharing options...
Dirk Posted October 9, 2010 Author Share Posted October 9, 2010 I think I have found what I'm looking for: http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Turbos/auction-323153976.htm http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Turbos/auction-323339457.htm Any comments on these products? Quote Link to comment Share on other sites More sharing options...
wysei82 Posted October 9, 2010 Share Posted October 9, 2010 I would not buy that is not gonna increase your power at all it will actually reduce power if anything. Quote Link to comment Share on other sites More sharing options...
Datsunrides Posted October 9, 2010 Share Posted October 9, 2010 I think I have found what I'm looking for: http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Turbos/auction-323153976.htm http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Turbos/auction-323339457.htm Any comments on these products? Ummm, I would not waste my hard earned money on those gimmicks. The only thing those do is help the acceleration of cash out of your wallet! I was wondering if there is a way to channel air into a carburetor by using some sort of air scoop. I guess you could somehow run a tube from the grille area to the stock air cleaner nozzle. This will net you a cold air intake and a slight "ram air" effect at highway speeds. Could this be done without channeling bugs and bad weather in there too? Sure, it's called an air filter. would it help increase engine power? You may see a couple HP for your trouble Mark Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted October 9, 2010 Share Posted October 9, 2010 Here you go Electric Turbo Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted October 10, 2010 Share Posted October 10, 2010 (edited) On another forum I'm on there is a Ford Probe track car that has a ram air intake under the front. They get 5 psi at 70 mph. http://forums.probetalk.com/showthread.php?s=&threadid=1701047435 Edited October 10, 2010 by soobenthusiast found the link Quote Link to comment Share on other sites More sharing options...
Dirk Posted October 10, 2010 Author Share Posted October 10, 2010 Cool! The thing that still bothers me though is still the rain and bugs and dirt being directed straight at the air filter. Maybe ok for a track car but not so handy for a daily driver. Quote Link to comment Share on other sites More sharing options...
Datsunrides Posted October 10, 2010 Share Posted October 10, 2010 Just built a shroud around wherever you place your intake or simply angle the tube off horizontal. This will deflect the rain and bugs for the most part. Mark Quote Link to comment Share on other sites More sharing options...
maudsland Posted October 11, 2010 Share Posted October 11, 2010 Well the rain would be good to cool the charge under the high boost you might experiance, regards to the bugs i hear that the juice from the bugs are high in octaine so it should prevent more detonation. Cheers Thierry Quote Link to comment Share on other sites More sharing options...
soobenthusiast Posted October 12, 2010 Share Posted October 12, 2010 Actually, I think that she says the water and bugs are not a problem, as there is a filter and the water would have to go up a couple feet to get in the motor. But I think I would also be wondering about it for daily driver duty. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted October 12, 2010 Share Posted October 12, 2010 I put a super duper dryer hose cold air intake on my escort in highschool, 3 months later the car wouldn't run for nothin, had issues at high rpm high load and would only really putter around. Turns out the cold air intake did a fabulous job of funneling a whole bunch of road debris, bugs, rocks and leaves to the air filter and clogged it. As has been said, gimmicks are only good if you're the one making the money off them, a properly tuned engine will get you more power than those gimmicks. Ram air does work, at high speeds if you do it right and have a big scoop and a good frontal pressure area to get a pressure buildup from. Is it worth it? not for my time or money. Quote Link to comment Share on other sites More sharing options...
Dirk Posted October 12, 2010 Author Share Posted October 12, 2010 I put a super duper dryer hose cold air intake on my escort in highschool, 3 months later the car wouldn't run for nothin, had issues at high rpm high load and would only really putter around. Turns out the cold air intake did a fabulous job of funneling a whole bunch of road debris, bugs, rocks and leaves to the air filter and clogged it. As has been said, gimmicks are only good if you're the one making the money off them, a properly tuned engine will get you more power than those gimmicks. Ram air does work, at high speeds if you do it right and have a big scoop and a good frontal pressure area to get a pressure buildup from. Is it worth it? not for my time or money. Cool. I wasn't really looking forward to cutting a hole in the hood anyway. Nice to know it works though. Quote Link to comment Share on other sites More sharing options...
