benebob Posted February 26, 2004 Share Posted February 26, 2004 As the subject says. Can a EA-81 or 82 wheel be put onto a Justy? Quote Link to comment Share on other sites More sharing options...
mcbrat Posted February 26, 2004 Share Posted February 26, 2004 nope. ea series are all 4x140 stock, and I think the justy is like 4x100. maybe a little bigger.... Quote Link to comment Share on other sites More sharing options...
viehmann Posted February 26, 2004 Share Posted February 26, 2004 Justy bolt pattern is 4X100 just like a Honda, Nissan, and fwd VWs (Golf, Jetta) etc. Quote Link to comment Share on other sites More sharing options...
Esteban32696 Posted February 27, 2004 Share Posted February 27, 2004 My Justy has 12' wheels & I would like to go to 13'. What wheels will bolt right on?? Quote Link to comment Share on other sites More sharing options...
viehmann Posted February 27, 2004 Share Posted February 27, 2004 Any aftermarket 13" wheel with a 4X100 bolt pattern should fit if it has a FWD offset. I got a set of 13"X 6" chrome Epic wheels made by American racing wheels off of a 1988 Nissan Pulsar that I bought at a salvage auction. They bolted right on to my 88 4WD Justy with no problems. I even used the lugnuts off the Nissan as the stud thread and pitch are the same on both cars. I mounted a set of 165-65-R13 Bridgestone Potenza RE-92 tires on them so the tire circumfrence was the same as the 12' wheels and tires. (speedo has to by acurate you know!) You can go the cheap route and get a set of 13"steel wheels off of a 89-94 Justy GL FWD or 4WD. they also use the 165-65-R13 tires and will bolt right on an 88... No Problem! Hope this helps. Quote Link to comment Share on other sites More sharing options...
bigjim5551212 Posted February 27, 2004 Share Posted February 27, 2004 VW and Honda factory wheels are 13" from older models. You should find them at the wreckers Quote Link to comment Share on other sites More sharing options...
NV Zeno Posted February 28, 2004 Share Posted February 28, 2004 Toyota, Mazda, even Ford are 4x100. Quote Link to comment Share on other sites More sharing options...
