ej22 - ej22t wiring harness?
5 replies to this topic
#1 wagaru
wagaru
    USMB Regular
  • PipPipPip
  • 60 posts
  • deep in the heart of...
Posted 10 November 2010 - 01:10 PM
i need a harness to go from ej22 to ej22t, and i cant remember who makes those, but i know someone builds swap harnesses. i did a search, but i ddnt find what i needed and im on kind of a time crunch, does anyone remember who builds those? :confused:
sorry for the rush
#2 Numbchux
Numbchux
    EJ conversion addict
  • 6,827 posts
  • Saginaw, MN
Posted 10 November 2010 - 01:16 PM
OBD I EJ22? just switch the cam and crank angle wires, add the wires for wastegate control and pressure sensor, reroute the temp sensor wiring (it's on the other side of the coolant bridge), and you're done. don't need a whole merge.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,690 posts
  • Portland
Posted 10 November 2010 - 01:20 PM
Yes - as Numchux says they are very simple. Obviously you will also need the EJ22T ECU as well as the changes he outlined. The turbo only added the boost control stuff and changed a few wireing pins.
Also I will mention that the few wires which need to be swapped can be done at the ECU pins with much less drama than out at the actual sensors since many of those wires are sheilded, etc.
#4 wagaru
wagaru
    USMB Regular
  • PipPipPip
  • 60 posts
Posted 11 November 2010 - 03:44 PM
ahh ok that makes life much simpler ty for the heads up is there a source for the diagrams other than the fsm?
#5 Numbchux
Numbchux
  • 6,827 posts
  • Saginaw, MN
Posted 11 November 2010 - 04:47 PM
fsm are by far the best diagrams you'll find
#6 wagaru
wagaru
    USMB Regular
  • PipPipPip
  • 60 posts
Posted 12 November 2010 - 11:58 AM
aye, now i gotta go buy one, lol. sadly the gentleman im doing the swap for has decided to use an outback 2.5l, so given that im going to 2.5 obd2 to 2.2l non obd, i may still need that harness
correct me if im wrong but thats a whole different animal, yes?
