Power Steering Reservoir O-ring?
O-ring are pretty much o-rings, but I'm sure this type of application requires a specific size. There just isn't circumference of the ring to take into consideration, but the thickness of the ring for any specific application. I'd not tempt fate and get the correct one from Subaru.
  • 1 month later...
Subaru Lists two O-Ring P/Ns here:
http://www.subarupartsforyou.com/cp_partlistbymod.php?subcat=Suspension+%26+Steering%2C+Pump+%26+Hoses
34427AA060
34427AC000
Not sure which one you need.
There is a rebuild kit for the pump like this:
If you go to http://www.opposedforces.com and select your vehicle, it should give you the pump kit P/N. Or you can do as GD suggests (clean the gasket and reassemble it with Locktite 518).
Edited by Mike104
  • 3 years later...
