zacrody Posted November 15, 2010 Share Posted November 15, 2010 hi my name is zac i just got this car off craigslist for the snowboarding season since my bagged truck cant make it up to the mountain. well turns out its got trouble before its snow ready. 1. wen the throttle is 3/4 to wide open it dies or boggs down and will just die if i dont let up. 2. the car really doesnt heat up only stays on the bottom third of the temp. 3. my worst problem is not having heat its like a luke warm sometimes. well i hope you guys can guide me in the right direction thanks in advance Quote Link to comment Share on other sites More sharing options...
NorthWet Posted November 15, 2010 Share Posted November 15, 2010 hi my name is zac i just got this car off craigslist for the snowboarding season since my bagged truck cant make it up to the mountain. well turns out its got trouble before its snow ready.1. wen the throttle is 3/4 to wide open it dies or boggs down and will just die if i dont let up. 2. the car really doesnt heat up only stays on the bottom third of the temp. 3. my worst problem is not having heat its like a luke warm sometimes. well i hope you guys can guide me in the right direction thanks in advance !) Several possible causes, but dirty fuel filter tops my list. Others include the usual tune-up items (Plugs, wires, distributor cap/rotor, and timing). If it runs fine most of the time and starts to fall flat on its face under load, low fuel flow due to clogged fuel filter is most likely. 2) Subaru temp gauges are notoriously inexact. Just because it reads low doesn't mean that it is. However, coupled with your "not having heat" (I assume from the heater/defroster), I would guess that someone removed the thermostat. If true, they might have done so in some misguided attempt to relieve a cooling problem... like a clogged radiator. 3) see 2) Quote Link to comment Share on other sites More sharing options...
swampbrat Posted November 15, 2010 Share Posted November 15, 2010 ditto! and welcome to the board! do you know the history of the car? can you tell if it's been monkeyed with or well maintained? Quote Link to comment Share on other sites More sharing options...
zacrody Posted November 15, 2010 Author Share Posted November 15, 2010 well ill defnetly check out that fuel filter but i got the car from some random guy up in the hills and i think the thermostat might be removed cause its got another fan next to the stock one that always runs its all ghettoly put in there just jumped to a fuse in the panel... i dont think the heater core is plugged cause i took off the lines and they flow coolant. is there i way i can check to see no thermo? or just tear it apart and replace? do you know were this fuel filter could be located? Quote Link to comment Share on other sites More sharing options...
Olnick Posted November 15, 2010 Share Posted November 15, 2010 Welcome aboard, zacrody. If you post your questions in the New Gen Forum you'll get a lot more response. Quote Link to comment Share on other sites More sharing options...
True2Blue Posted November 17, 2010 Share Posted November 17, 2010 well ill defnetly check out that fuel filter but i got the car from some random guy up in the hills and i think the thermostat might be removed cause its got another fan next to the stock one that always runs its all ghettoly put in there just jumped to a fuse in the panel... i dont think the heater core is plugged cause i took off the lines and they flow coolant. is there i way i can check to see no thermo? or just tear it apart and replace? do you know were this fuel filter could be located? Hey man.. it COULD be a fuel filter but by the way it sounds you may not have one your gas tank can have a vacuum/not vent right.. if you want to find the filter simply follow the fuel line.. These cars are stupid simple or ill just take 5 minutes to make a pic for you Looks like this from the side I'd just pull the thermostat housing and check er out.. with a ghetto fan rigged up and no thermostat (low/no heat from heater core) ill promise you that your radiator is plugged up and that was a cheap "fix" look for a radiator and remove the rigged fan heres a parts link http://seattle.craigslist.org/oly/pts/2058059213.html Quote Link to comment Share on other sites More sharing options...
zacrody Posted November 19, 2010 Author Share Posted November 19, 2010 alright thanks man you guys are really helpfulll Quote Link to comment Share on other sites More sharing options...
