'88 Justy carb problems
2 replies to this topic
#1 Esteban32696
    USMB is life!
  • 158 posts
  • Florida
Posted 27 February 2004 - 07:11 AM
I have an '88 Justy, 2wd, with carb problems. It runs pretty good at speed, but will not idle. I do know that I need a thermostat. Never really warms up.Screw adjustments are not the problem. Parts stores want a ton of money for a rebuilt carb. Any other options????
#2 Esteban32696
    USMB is life!
  • 158 posts
  • Florida
Posted 29 February 2004 - 07:09 AM
Help ?
#3 Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 29 February 2004 - 08:11 AM
Check to make sure the anti-diesel solenoid is getting power and is not knackered.
Replace the tstat, you may have a feedback carb controlled by an ECU and if the engine temp is not up to closed loop op temp it may be causing problems.
Here is a forum dedicated to to the Justy
Hope this helps
