87 gl 10 turbo good for a build?
4 replies to this topic
#1 zues marine
zues marine
    New User
  • PipPip
  • 17 posts
  • Spokane 99223
Posted 20 November 2010 - 01:17 AM
wondering if the turbo from an 87 gl 10 would be a good turbo to use in a build on my n/a 2.5L in my 95 legacy
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 20 November 2010 - 01:27 AM
Too small to do much - the CFM of that turbo is pretty low. It will spool very quickly and give a boost to low-end torque, etc but it will likely run out of air-flow at higher RPM. A better choice would be a VF11 from a first-gen Legacy turbo or even a TD04 from a WRX.
#3 flight_of_pain
flight_of_pain
    USMB Regular
  • PipPipPip
  • 93 posts
  • spokompton
Posted 20 November 2010 - 07:26 PM
They are a bit small for the 1.8 they came on stock, much less a 2.5.
#4 presslab
presslab
    Subaru Nut
  • 621 posts
  • N. California
Posted 21 November 2010 - 11:36 AM
They blow a lot of hot air at high boost / high RPM. I upgraded mine to a TD04L and it is much, much better.
#5 Myxalplyx
Myxalplyx
    Old Wise and Dumb
  • 1,834 posts
  • New Castle
Posted 21 November 2010 - 02:01 PM
Would be great for a Justy, I think. Not so great for a 2.5ltr, which is twice a big. However, if you choose to go this route, be sure you have a good intercooler. If you keep your exhaust gas temperatures in check, then your low end would be great but your top end would probably suffer a little.
Edited by Myxalplyx, 21 November 2010 - 02:04 PM.
