clutch selection question EA82
7 replies to this topic
#1 Guest_baccaruda_*
  • Guests
Posted 11 August 2003 - 11:40 PM
Hi.. I'm going to plan on Skeet's wagon needing a clutch and will be buying a kit soon.
His wagon is carbureted.. will I get a stronger clutch if I order one for a turbo? Or are all EA82 clutches pretty much the same?
#2 Guest_GlCraigGT_*
  • Guests
Posted 12 August 2003 - 01:51 AM
To my knowledge there are 3 EA82 clutches.
2WD (smallest in diameter will need a different flywheel to upgrade to 2wd turbo)
2WD Turbo (same diameter as 4WD/4WD Turbo but the dampening springs are different, Pressure plate maybe the same as 4wd/4wd turbo.)
4WD/4WD turbo
#3 Guest_Skip_*
  • Guests
Posted 12 August 2003 - 08:48 AM
There is one other "factory" clutch set up that will work
The XT6 setup
most parts store books list it as the same as the EA82T setup but I have heard the factory pp is stonger
#4 Guest_baccaruda_*
  • Guests
Posted 12 August 2003 - 09:51 AM
thanks guys..
hmm. skip, think it's "too strong" for a carbureted EA82?
#5 Guest_Skip_*
  • Guests
Posted 13 August 2003 - 07:02 AM
no Andy it will just grab the clutch disc better and in the long run be the ticket for your "race mods"
#6 Guest_baccaruda_*
  • Guests
Posted 13 August 2003 - 10:00 AM
cool! think it will be too hard on the clutch cable or Skeet's left foot? :)
thanks skip!
#7 Guest_skeetar_*
  • Guests
Posted 13 August 2003 - 10:40 AM
Don't worry about my foot, I have Kung Fu legs.
#8 Guest_baccaruda_*
  • Guests
Posted 13 August 2003 - 11:07 AM
your Kung Fu legs are impressive.. but they are NO MATCH for the HEAVY-DUTY SEMI-TRUCK CLUTCH I'm going to put in.. MWAHAHAHAHA
