Pics of new dash gauges 86 ea82t
11 replies to this topic
#1 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 28 February 2004 - 12:52 PM
Go here and check it out,
Click on New Dash
http://f1.pg.photos....l.net/my_photos
I was torn about putting an exhaste gas temp in instead of oil pressure, But I would have to weld on a bung and I had the oil pressure gauge around, so there it is.
bty this is on the 86 turbo wagon in the sig.
#2 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 28 February 2004 - 12:56 PM
is that plate that you used premade? or did you have to fab it yourself?
I want some extra gauges in my car, and i could never find a good spot. That center console spot is a great idea
#3 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 28 February 2004 - 04:10 PM
All hand made, put some miles on the die grinder
#4 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 28 February 2004 - 04:12 PM
wow man that thing looks nice:D Someone put some guages in my 86 turbosedan in the same spot but it looks pretty bad. Maybe I'll have to do something similar to yours so it helps clean it up a bit. Oh and question, how did you get that plate to mount in there? I see the screws but I can't figure it out
#5 83projectbrat
83projectbrat
    Eat, Live, Breath Subaru
  • 269 posts
  • minnesota
Posted 28 February 2004 - 05:35 PM
wow im impressed, that really looks good. i have a 2000 subaru rs and i want the gauges on top my dash.. and i want to buy the subaru guage top thing and fab something so ill need plastic and i was wondering where you got that plastic from? thanks man
matt
#6 nutt7
nutt7
    certified hoser!
  • 241 posts
  • Tempe
Posted 28 February 2004 - 06:03 PM
if its the same plastic I am thinking of, it is called ABS. any custom stereo shop should have some. they come in like 8" squares.
#7 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 29 February 2004 - 12:19 PM
The black material that I used to mount the gauges to is road sign aluminum, my dad works in construction so he always has road sign sitting around, I think it is 1/16th thick. You can also find this material at a steel supply or OSH or something like that. Thanks nut for the tip on where to find it, I never thought of useing plastic, but it would be easier to work with.
First I made an autocad template from some measurements of the opening. Made the drawing as acurate as possible. Printed out the template and glued it on the alluminum, cut it out then trimmed it to fit, took a while.
Ah yes the hold down bolts that was a little bit of a streach, basically I made extentions for the bolts with coathangers. Original bolt lenth 1 inch, finished lenght, 6 inches. I cut out the bottom of the storage compartment except for the corners. drilled holes in the corners and put the bolts through the whole shabang! I hope that makes sense, I forgot to take any pics of the altered case.
#8 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 29 February 2004 - 12:49 PM
Subi, very clean instal, looks factory.
I made a smaller plate and mounted my boost gage,
A/F ratio, and digital voltmeter
The problem I had was they hard too watch while driving.
I remounted them in a A pillar pod and put not quite as
often checked gages in it. ( trans temp, fuel pressure, and ammeter)
A pillar pod mounts are available at Jegs.
Posted Image
#9 subarubrat
subarubrat
    1000+ Super USER!
  • 1,447 posts
  • Bealeton, VA
Posted 29 February 2004 - 12:54 PM
I DO like that digital.....
#10 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • 6,273 posts
  • Portland, Oregon
Posted 01 March 2004 - 12:00 AM
Wow, looks nice :D
#11 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 01 March 2004 - 12:53 AM
Ya Skip I totaly agree it is a little bit of a strech to watch them while driving, But I couldn't think of any other place to mount them.
I had no idea they made A piller monts that fit subaru trim. Maybe I will have to look into that.
Skip where did you get that digital volt meter? that is pretty nice
#12 iluvdrt
iluvdrt
    Overland Brat Builder
  • 967 posts
  • Oceanside, Ca
Posted 01 March 2004 - 02:29 PM
i think the pillar pods are the universal kind. they also sell them at auto zone. i bought one and mounted it, but it didnt look good enough for me so one of my airframer buddies is going to use it as a template to make one out of fiberglass for me. ill let everyone know how it turns out.
