ej22 timing belt vs ej25 belt
4 replies to this topic
#1 bheinen74
bheinen74
    Banned
  • Banned
  • Pip
  • 0 posts
  • central Iowa
Posted 07 December 2010 - 11:35 AM
Are the ej22 and ej25 sohc timing belts the same?
I have a used ej22 belt in near new shape, going to put it on my Baja engine if its the same?
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 07 December 2010 - 11:48 AM
I don't see how it will be different in terms of size, length, etc. Where it might be different is in its construction. It may be built to go 100,000 miles between change intervals, where most of the ej22 belts are designed for 60,000 change intervals. The exception to this is california spec belts, which I believe are also 100,000 mile change intervals.
#3 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 07 December 2010 - 04:23 PM
Phase 1 EJ22 and Phase 2 EJ25? Or Phase 2 to phase 2? P1 to P2 will not work. P2 to P2 are the same.
#4 Goobysoobs
Goobysoobs
    USMB is life!
  • 165 posts
  • Raleigh, NC
Posted 07 December 2010 - 05:55 PM
doesn't the ej25 have 2 extra cams? Wouldn't that require it to be longer?
#5 Qman
Qman
  • Moderator
  • 11,119 posts
  • Sumner
Posted 07 December 2010 - 08:25 PM
Do some research. EJ25 came DOHC and SOHC.
