4 inch lift
23 replies to this topic
#1 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 18 December 2010 - 02:56 PM
I have been doin some reading and i have seen people pulling motors out for a four inch lift. Does a guy have to pull the motor and for what?
#2 3eyedwagon
3eyedwagon
    Build it, don't buy it!
  • 708 posts
  • Apache Junction
Posted 18 December 2010 - 03:33 PM
You're probably better off doing so in the long run. While it is not 100% necessary; it is probably alot easier than leaving it in. Since you are seperating the crossmembers from the body, and placing blocks in between the two it is easiest to have the crossmembers as light as possible. Having the engine, and transmission still in the car/hooked to the crossmember adds a couple hundred pounds to the weight you'll be maneuvering around to get the blocks lined up. Obviously that's going to add some difficulty to balancing all that crap on a a trolley jack. Having the engine/trans removed also makes it far easier to add links from block to block strengthening your lift. Making the steering linkage will also be worlds easier without the engine in the way.
#3 Bash
Bash
    USMB Regular
  • PipPipPip
  • 73 posts
  • Amarillo Texas
Posted 18 December 2010 - 04:35 PM
I did my SJR 4" lift By myself with jack stands and a floor jack. Didn't have to remove the engine. I did take off the exhaust and driveline, also disconnect the shifting linkage and drain the radiator. I had to cut off about 1/2 inch of the bottom rad hose the top hose still fit with no mods. I did the rear first. Then the front.
#4 iamvandemon
iamvandemon
    New User
  • PipPip
  • 21 posts
  • scranton
Posted 18 December 2010 - 11:33 PM
I had replace my top hose with an extended one after it tore in half.. n had to modify the break line mounts in the wells to accomidate the lift.
#5 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 18 December 2010 - 11:43 PM
great info guys thanks a ton. im probably gonna start tearin into this thing tomorrow if the warden (my wife) will let me.
#6 michael appel
michael appel
    Certified Subaru Nut
  • 779 posts
  • wilsonville Or
Posted 19 December 2010 - 12:07 AM
Ive done five lifts never pulled a motor just make sure your pitch rod is out and the ground to the motor is disconnected and go
#7 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 20 December 2010 - 02:05 AM
Well i got the tires on it today. didnt get to spend much time on it. Anyway I put 235 75 15's on it. a little fender trim and yes it does rub but not a whole lot. Im waiting on the steel for the lift. should have it in a few days.
#8 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 22 December 2010 - 10:17 AM
i thought for sure there would be more replys on this. I didnt think id be the last to post on it thats for sure. Guess its not all that interesting really.
#9 LegacyBrad
LegacyBrad
    USMB Regular
  • PipPipPip
  • 48 posts
  • Prescott AZ
Posted 22 December 2010 - 12:58 PM
Is it just the pics or are those tires shot?
Oh, and stop crying over the lack of posts, its a pretty new thread. It looks like a nice project, but not much else is going on yet. I'm in for the lift pics later.
#10 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 23 December 2010 - 08:42 AM
no crying. this palce is usually pretty busy. i was just sayin that just puttin tires on it wasnt that interesting.
#11 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,375 posts
  • Seattle
Posted 23 December 2010 - 11:01 AM
When we first fired up the USMB, bigger tires woulda had every member commenting and raving. When we lifted that first one, the place went nuts. When we gathered the first group of them together, the place really hit the roof. (wait, that was pretty much pre-internet)
Once the off road forum has seen pics like the one below, a set of balding tires crammed under a stock mobile isn't all that gnarly.
http://www.hatchpatr..._serialNumber=2
Lift it, show it stuck in a big mud hole or hanging off a rocky ledge. . . They'll love it.
Welcome.
#12 michael appel
michael appel
  • 779 posts
  • wilsonville Or
Posted 23 December 2010 - 03:47 PM
unfortunately he is right but I do like your rims and it will be cool for sure cant wait to see the progress also remember it is christmas not alot of people are on here
#13 987687
987687
    Rally Suby!
  • 4,262 posts
  • Northern Maine
Posted 23 December 2010 - 11:01 PM
I'm on here to get away from family and guests haha.
#14 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 24 December 2010 - 09:42 AM
Ill prolly be out in the shop building the lift to get away from family.
P.S. I wasnt tryin to get anything stirred up. I completly understand. This is a great site with a ton of information.
#15 987687
987687
    Rally Suby!
  • 4,262 posts
  • Northern Maine
Posted 24 December 2010 - 09:52 AM
Thing is, just about everything has been done to a subaru on here. It takes a crapload of ingenuity to create something nobody has done before on here.
But then I'll go and post my car on my local subaru forum and nobody has ever seen anything like it before. Don't even know that subaru made a 4x4 with lo range, etc.
I took it on a rally drive with some of the local club members and nobody knew what to think about the thing.
But then I go and post it on here, and it isn't anything special.. Just a sedan lifted 2" with pugs and 27" wheels.
There's some pretty crazy cool stuff people have built on here, just search around.
#16 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 24 December 2010 - 10:03 AM
I have seen alot of neat stuff on here. I never had any intention to do anything to my subaru until i found this site. since then i have been dying to get my loyale in the air. Super excited to get it lifted. I cant wait so post some pics of it covered in mud. I appreciate all the information being passed around. As long as this site is running ill be lookin up info on here. Everyone on here has a vast knowledge of subaru's and how to beef them up. Without this site id still be driving on 13's. Anyway thanks for all the info on everything subaru. Awesome site.
#17 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 24 December 2010 - 10:32 AM
...stop crying over the lack of posts, its a pretty new thread. It looks like a nice project, but not much else is going on yet. I'm in for the lift pics later.
Sometimes people are very Busy with other Threads...
in Example: I Posted a Couple of Years Ago that I was Painting my White Weberized Wagon in Yellow, but not like my Other Yellow Wagon
(The ER27 Wagon was Dark Yellow) I Painted my White Wagon in Bright Yellow and Black, I Posted a thread in the "Playground" forums we had after the Site went Down for a While, in 2008...
Then I Posted
This Thread a Couple of Years Ago, Tryin' to Bring back that, but No one posted a single Reply...
Then I Posted
This Thread about my First 25 Years Owning my Weberized EA82 Wagon, but also seems like it wasn't very interesting...
I Understand that there are other more interesting Threads...
I'm Here Trying to do my Best to Help Others with Ideas and Share my Experiences & Knowledge... well, that's the Idea of this Forum.
Kind Regards.
Edited by Loyale 2.7 Turbo, 08 May 2013 - 11:00 AM.
#18 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 24 December 2010 - 11:08 AM
Exactly what im saying
#19 michael appel
michael appel
  • 779 posts
  • wilsonville Or
Posted 25 December 2010 - 01:11 AM
Although there does need to be a good link to write ups on lifting and building so pffffft
#20 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,375 posts
  • Seattle
Posted 25 December 2010 - 11:33 AM
That's fair. The first one was a learning experience. Some 19 or so lifts installed later, it's a walk in the park. After 3 or 4, PK quit wasting paper and stopped sending directions.
#21 michael appel
michael appel
  • 779 posts
  • wilsonville Or
Posted 27 December 2010 - 10:48 PM
LOL
I am putting up a website that will show how to 2.2 swap and lift all years of subarus
#22 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 28 December 2010 - 12:22 AM
id love to have a 2.2 instead of the 1.8.
#23 kenpdx
kenpdx
    USMB Regular
  • PipPipPip
  • 58 posts
  • Ketchum, Idaho
Posted 28 December 2010 - 09:05 PM
LOL
time frame on that one?:D
#24 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 7,528 posts
  • Roatán, Honduras.
Posted 29 December 2010 - 02:35 PM
I'll Love to have a 2.2 instead of my Dead 2.7 ...
~► http://www.ultimates...-my-27-project/
Edited by Loyale 2.7 Turbo, 08 May 2013 - 11:06 AM.
