Throttle Position sensor
you can check it if you have a good DVOM.
there is also the closed throttle switch built into the tps.(the flat connector)
TPS has the round connector.
back probe on the signal wire (green I think it was) and with the key on verry slowly open thew throttle and look for a smooth voltage transition. don't bother with the ohms BS. checking voltage will tell you more.
