found sets of pistons on ebay 140 shipped na or turbo. Looking at rebuilding a 86 MPFI EA82T. Alot of Nissan Z31 owners swap na 9:1 pistons into their turbo 3.0L V6. This creates faster spool and better fuel economy. I dont plan on running higher boost than stock and will mount a FMIC to help with detonation, also highest octane available at a gastation. 1986 GL Turbo Wagon
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
ea82 na pistons in ea82T
Started by
mike300z
, Jan 18 2011 05:47 PM
4 replies to this topic
#1
Posted 18 January 2011 - 05:47 PM
#2
Posted 18 January 2011 - 06:40 PM
Good luck.
#3
Posted 18 January 2011 - 06:42 PM
I have run mpfi turbo on a carb ea82 block with 9.0:1 compression. You should be ok with stock parameters. You can save yourself all the work and find a solid shortblock from a carb ea82.
#4
Posted 26 January 2011 - 11:39 AM
what will that do, turbo blocks have a extra hole tapped in it for knock sensor
#5
Posted 26 January 2011 - 12:46 PM
The hole is there on all EA82s. Usually tapped, but if not, that's easy.
The ACTUAL difference in the blocks is the large PVC port on the case. It really isn't a big deal Just hook up PCV like an SPFI would be.
But if you really WANT to swap pistons that's fairly easy, without splitting the case.
Don't up boost with this setup......the NA piston tops are much thinner than the Turbo ones.
