flatfour73 Posted January 26, 2011 Share Posted January 26, 2011 I am getting steam in the crank case. i havechanged the head gaskets twice now and still same. any advice or experience with this prblem? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 27, 2011 Share Posted January 27, 2011 There is an o-ring between the block halves on the top of the engine. MAybe this could be your problem? It is one way to introduce coolant to the crankcase. This is just an idea. pressure check can help prove or disprove this. Put your ear to the fill tube while the system is pressurized, and listen for steam. You could run the car to operating temperature, and then turn it off to do this. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted January 28, 2011 Share Posted January 28, 2011 Moved to historic. Assuming its a 70's model which may be a mistake but 50-50 chance. Quote Link to comment Share on other sites More sharing options...
