Goatboy Posted March 3, 2004 Author Share Posted March 3, 2004 Check Engine light is out! Woo Hoo --GoatBoy-- Quote Link to comment Share on other sites More sharing options...
rallyruss Posted March 4, 2004 Share Posted March 4, 2004 so what was it? have you test diven it for a while? Quote Link to comment Share on other sites More sharing options...
Soobadooba Posted March 4, 2004 Share Posted March 4, 2004 Cool! You got a solenoid from the junkyard? Did you use the same meter or a different one? -Louis- '91 Loyale 4wd 5spd Wagon Quote Link to comment Share on other sites More sharing options...
Partsman Posted March 4, 2004 Share Posted March 4, 2004 Your meter may be SLIGHTLY out of calibration, but it's not unusual to see a digital meter read something other than infinity. Maybe you have high humidity and there's a little conductivity in the air? And on the staying at 0 ohms after taking the leads apart - do you have some sort of latching function that shows what the lowest ohm reading reached is? Those Flukes are awesome units, and have a lot of features my Craftsman meter doesn't. Quote Link to comment Share on other sites More sharing options...
bushbasher Posted March 4, 2004 Share Posted March 4, 2004 dude I had the same fluke meter as you, and it did the same kind of things as yours. Mines like 10yrs old and it finally went screwy. My voltage readings are incorrect and ohms readings jump around from 0 to OL (unmeasurably large resistance/open circuit). You could fling that thing onto the concrete and it wouldn't be fazed. My dad just got a newer fluke 77 and he accidentally drove over it with the car, with no damage to the meter (except tire marks) Those flukes are very well built, very accurate, but expensive (my dads 77 cost over $200) Quote Link to comment Share on other sites More sharing options...
Goatboy Posted March 4, 2004 Author Share Posted March 4, 2004 Yes used a different meter Got a good EGR Solenoid from the JY Tested my Purge Solenoid and it was fine. Cleaned contacts and hooked everything back up. After the Purge Solenoids heats up it shorts though. Will need to be replaced Thanks all for your help --GoatBoy-- Quote Link to comment Share on other sites More sharing options...
Partsman Posted March 5, 2004 Share Posted March 5, 2004 That FSM I pointed you to earlier states that the EGR solenoid is supposed to be 32.7 to 39.9 ohms to be good. Quote Link to comment Share on other sites More sharing options...
