Timing belt covers
4 replies to this topic
#1 Matthewboerner
Matthewboerner
    USMB Regular
  • PipPipPip
  • 51 posts
  • Medford, Oregon
Posted 12 February 2011 - 09:01 AM
I'm wanting to run my ea82t timing belt coverless, but from what I've seen other usmb users leave the one back piece just under the water pump. Is it useful to leave that one on or can it be removed along with the other pieces of the timing belt cover assembly? Thank you -matt
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,658 posts
  • East Coast
Posted 12 February 2011 - 09:43 AM
you don't need to leave any of them in place. the rear piece isn't required to be removed for timing belt purposes so it's an extra unnecessary step for someone just doing a timing belt job.
belt covers have accommodations for the oil pump sending unit wire or the oil dipstick.
i run the wire behind the belt and believe I usually run it behind the passengers side tensioner to keep away from the belt.
the dipstick i think i leave the center timing cover in place (using only two bolts so it's easy to remove) so as to keep the dipstick holder in place.
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 12 February 2011 - 10:31 AM
That piece is left on as it is the only place where the belt is exposed on the back side. I usually leave that piece in.
#4 Matthewboerner
Matthewboerner
    USMB Regular
  • PipPipPip
  • 51 posts
  • Medford, Oregon
Posted 13 February 2011 - 08:26 AM
Thank you for your help guys, I really like the open belt look so I'm going for it!
#5 Deener
Deener
    Eat, Live, Breath Subaru
  • 352 posts
  • Vancouver BC
Posted 14 February 2011 - 09:07 AM
I agree, the covers are just a PITA when you have to get in there for anything. I leave the ones behind the cams on just so I don't stick my finger in there while checking for problems. I use little zip straps to fasten the sending unit wire to the dipstick, works good.
