Dirk Posted February 15, 2011 Share Posted February 15, 2011 Here are some before and after pics of my port and polish job on EA71 Heads. More to come as I progress. Quote Link to comment Share on other sites More sharing options...
Dirk Posted February 17, 2011 Author Share Posted February 17, 2011 Just been on the phone to Kelford Cams. The guy was really nice. He can fix me up with a suitable grind for about $150 NZ The only thing is he did hint that there is more to porting than meets the eye. It seems that you can make the engine run worse than before if you take off too much material in the wrong places. I couldn't really take up too much of his time by trying to explain what I have done. So I wonder If any of you can point me in the right direction for these heads. Cheers Dirk Quote Link to comment Share on other sites More sharing options...
GTlegs Posted February 20, 2011 Share Posted February 20, 2011 As a starter, the intake side should have texture (ie not be mirror finish) as this helps the fuel and air mix. Quote Link to comment Share on other sites More sharing options...
Dirk Posted February 20, 2011 Author Share Posted February 20, 2011 Yes I have heard this. It seems to be a fiercely debated topic. But I believe those that say the fuel is vapourised in the carb long before it reaches the intake ports. Quote Link to comment Share on other sites More sharing options...
Ross Posted February 26, 2011 Share Posted February 26, 2011 Essentally you want to try maintain a similar cross sectional area along the runners. Concentrate more on smoothing out where the intake meets the heads -- I have found this area leaves much to be desired. You'll need to cut the intake gaskets to match -- again, these are terrible as standard. Areas of larger cross section encourage the fuel to condensate out of the air -- not good. Best to leave things similar to factory unless you have a very good reason not to.... Quote Link to comment Share on other sites More sharing options...
Dirk Posted February 27, 2011 Author Share Posted February 27, 2011 Cool. Thanks Ross Quote Link to comment Share on other sites More sharing options...
Dirk Posted March 30, 2014 Author Share Posted March 30, 2014 Comments/advice welcome. Cheers Dirk Quote Link to comment Share on other sites More sharing options...
tweety Posted April 19, 2014 Share Posted April 19, 2014 I'm an older bloke 58yo and never seen the results of port and polishing. thanks for the thread. its making sense. Quote Link to comment Share on other sites More sharing options...
Dirk Posted April 22, 2014 Author Share Posted April 22, 2014 Thanks. Just remember........ I dont have the first clue into what I'm doing. Hopefully someone will chime in with some technical feedback. ( best advice I have had so far is to spend money on a good valve grind) With best regards Dirk 1 Quote Link to comment Share on other sites More sharing options...
Datsunrides Posted April 24, 2014 Share Posted April 24, 2014 I am far from an expert on porting, but here is my 2 cents. Unless you plan to make your engine "breathe" better, through bigger carbs, racy cam, and large exhaust (read increase the RPM's), porting will may little if any difference to a stockish engine. You would probably get better results doing a simple port match and cleaning and deburring and a nice 3 to 5 angle valve job. There are other tricks like larger valves and cut down guides etc, but once again, you would only see results at higher revs. Mark Quote Link to comment Share on other sites More sharing options...
