newb
4 replies to this topic
#1 vicali
vicali
    New User
  • Pip
  • 1 posts
  • Kam, BC
Posted 16 February 2011 - 12:51 PM
New here, I've been here before but just registered today.
We have a 08 Forester as a family car, and I've been looking for a daily driver/ TSD Rally car to turn a wrench on..
I've looked at many different options, and have been watching CL and Kijiji for the right one to come along.
Today this showed up;
1990Loyale Wagon
So I'm here looking around..
mike
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 16 February 2011 - 09:12 PM
Not a bad price for the mileage and year. it will have a pushbutton 5spd manual 4wd trans. The 4wd mechanism is electric/vacuum that actuates a mechanical linkage(can be actuated manually if it fails)
Assuming no maintenance history, it may be on its original timing belts. Easy enough to repair of it breaks, though, non-interference.
Parts are interchangeable between 1985 and 1995 DL/GL/GL-10/XY/RX/loyale coupe, sedan, wagon
rear disc brakes form a turbo swap in
a dual range trans is a direct bolt in using the same axle, clutch, mount, and driveshaft
you can swap in missing accessories such as rear speakers, map lights, power windows from any gl or loyale equipped with such
The car is novel and practical, but not the best in performance(raw power and torque, although it is high revving and handles tightly), but is a good car if you appreciate its versatility. The car will be reliable so long as you understand subaru specific maintenance practices. This car is easy to work on compared to most other makes, but is much different than other makes.
#3 TheLoyale
TheLoyale
    Safariwagon: The Legend
  • 7,067 posts
  • Waukesha, WI
Posted 17 February 2011 - 12:03 AM
If you look at the interior picture closely, you can see the picture shows a 3AT shifter cause the 4WD button is on the side Vs. on top of the shifter.
So, is this car really a M/T? hmm.
#4 Olnick
Olnick
    Ol' Subaru Guy
  • 2,977 posts
  • Honolulu HI
Posted 17 February 2011 - 12:35 PM
. . . the picture shows a 3AT shifter . . .
Good eye, TheLoyale! I think you're right.
#5 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 17 February 2011 - 01:42 PM
If its a 3at 3spd auto, consider looking still. If its a 4eat (4spd electronic) that is better.
The 4eat is the same design up to 2004 automatic subarus, so in theory, you can swap in one from a legacy and use an ej22 if you were into it for a project.
otherwise, you can use a legacy trans and swap over your existing differential to match the bellhousing.
If the car has a good service history, it will not be a bad choice for 600 bucks.
if you are really into it for a project, you can swap in a manual trans using the same running gear, you just need the mount, driveshaft, and clutch/flywheel assembly, and its related bolts.
