Suba_GL_87 Posted February 17, 2011 Share Posted February 17, 2011 my car is subaru gl 87' 1.8L. my wagon have badly oil leak from head gasket and there's muddy oil when i parking lots. those made me headache buy new oil pint turn over again. im fed-up and buy new head gasket. anyways; when i was remove a valve cover and there have a cam-lobe. so, i try remove a block of the cam-lobe. it's hard to remove also stuck. But somehow the cam-lobe's valve's a part fell down made me very anxious (look like a *rectangle with sliver there a hole* for support valve to cam-lobe) i don't know what called it. so, i did struggle a little longer try to put back away but helpfully i put some sticky grease on valve between cam-lobe and go back together. so, i've been looking around internet and try think how to replace head gasket. feedback me! Quote Link to comment Share on other sites More sharing options...
Olnick Posted February 17, 2011 Share Posted February 17, 2011 You'll probably get more response if you post your question in the Older Generation Forum. Good luck. Quote Link to comment Share on other sites More sharing options...
