Bent Rod
6 replies to this topic
#1 Casino Loyale
Casino Loyale
    New User
  • Pip
  • 9 posts
  • Pacific
Posted 26 February 2011 - 05:34 PM
when hydrolocked whats more likely, bending a rod or forcing a spark plug out?
for an EA82 that is
Edited by Casino Loyale, 27 February 2011 - 01:03 AM.
#2 naru
naru
    1000+ Super USER!
  • 2,242 posts
  • under the bridge
Posted 27 February 2011 - 03:08 AM
Bending a rod.
Don`t see how you could force a plug out unless the threads were already stripped.
#3 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 27 February 2011 - 02:08 PM
for an EA82 that is
Your original post said that it hydrolocked while attempting to start rather than while running, correct? If so, bent rods are nearly impossible: Starter at best produces 2HP, compared to at least 40HP that these rods can take in normal use. Same with sparkplug under these conditions.
Maybe/possibly blow out an already failing HG due to shock load, but if so it wasn't going to last much longer anyway.
#4 Casino Loyale
Casino Loyale
    New User
  • Pip
  • 9 posts
  • Pacific
Posted 27 February 2011 - 10:43 PM
yes, the HG did blow. But now the bearings are making noise in the crankcase.
#5 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 28 February 2011 - 02:10 AM
Are you sure it is a rod knock, and not something else? e.g. - the HLAs (hydraulic lash adjusters)
Any idea how long the bearings were exposed to water in the oil? (As in, was this a one-time "things went bad", or a chronic exposure over weeks/months.) Possible that the bearings were damaged by exposure to coolant and started to come apart; might already have been doing so, and this aggravated the problem.
#6 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 28 February 2011 - 02:44 AM
Have you checked the crankcase for coolant?
Like NW said, coolant will ruin the bearings.
#7 Casino Loyale
Casino Loyale
    New User
  • Pip
  • 9 posts
  • Pacific
Posted 01 March 2011 - 04:38 PM
Water was in the oil for 10 miles. Only water no coolant.
Now it makes a dull banging when the oil is low so I'm looking for an oil pressure tester or gauge.
