Scanning OBD2 codes
7 replies to this topic
#1 CJK440
CJK440
    USMB Regular
  • PipPipPip
  • 30 posts
  • Connecticut
Posted 03 March 2004 - 05:07 PM
Any way to pull codes off my 96 Legacy without a scanner??? Like jumping some pins on the diagnostic connector and reading the Check engine light???
How about clearing codes??? Do I need a scanner to clear the codes???
#2 Brett_j
Brett_j
    USMB Regular
  • PipPipPip
  • 48 posts
  • Perth
Posted 03 March 2004 - 07:18 PM
Click Me :D
#3 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 03 March 2004 - 07:28 PM
MY '96 vehicles use OBDII, so you will need an OBDII code reader to read and clear the codes.
#4 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,952 posts
  • Denver, Colorado
Posted 03 March 2004 - 07:29 PM
Autozone used to pull codes at no charge.
Clear them by disconnecting the battery and letting it drain overnight. (not sure on actual length of time but overnight works).
#5 Brett_j
Brett_j
    USMB Regular
  • PipPipPip
  • 48 posts
  • Perth
Posted 03 March 2004 - 07:44 PM
I thought the basic codes could still be pulled,stupid lying article,oh well my bad.
In regards to resetting the ECU,I have always disconnected the negative and just put my foot on the brake pedal for about a minute,seems to drain any power from hte system and has worked on all my cars,maybe the OBD II is different though?
Still learning.
#6 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 03 March 2004 - 07:45 PM
From Subaru document:
On Board
Diagnostics-II
(OBD II)
Module 407
"DTC Memory
Memory of a DTC (as it relates to illuminating
the MIL) is maintained until 3 consecutive
passing trips have been made. (The Enabling
Criteria was reached 3 times in a row and the
tests were performed with good results). The MIL
will turn off at this point.
The DTC will remain available for viewing with
the select monitor and the freeze frame
information associated with it for 40 warm up
cycles.
The exception to this rule is if the code is
associated to misfire or fuel trim which will require
80 warm up cycles for full erasure."
#7 Brett_j
Brett_j
    USMB Regular
  • PipPipPip
  • 48 posts
  • Perth
Posted 03 March 2004 - 07:58 PM
Thanks,now Im totally confused :D.I'll juat get the nice man in the overalls to look at my car :D.
#8 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 03 March 2004 - 08:05 PM
Maybe a little more info would help.
DTC = diagnostic trouble code ( i.e. P0400, my favorite)
MIL = malfunction indicator lamp (check engine light)
"Before OBDII can begin to work the vehicle must
meet the “Enabling Criteria”. This is the vehicle
operating condition that must exist for the Engine
Control Module (ECM) to begin diagnostics.
“Enabling Criteria” will not be the same for all
diagnostics. For example; the ECM checks an
EGR solenoid as soon as the ignition is turned
on."
