Which bolts/nuts did they loosen?
2 replies to this topic
#1 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,105 posts
  • East Coast
Posted 01 April 2011 - 11:00 AM
Had a set of SOHC EJ25 heads (2000) resurfaced and pressure tested. Shop said they loosened some bolts/nuts in order to resurface them - which ones?
Would they loosen the nuts on top of the valve springs or the bolts holding the valve train/cam in place?
They said they torqued them down but I'd like to check the torques and possibly even retorque them.
#2 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
  • Pittsburgh suburbs (NE)
Posted 01 April 2011 - 11:16 AM
I always send them bare heads.
Less chance of crap being in the heads even after their steam bath gizmo.
Also then I know tha status of everything. Check for abnormal wear, use assy lube, proper torque's, etc.
#3 GeneralDisorder
GeneralDisorder
  • 22,064 posts
  • Portland
Posted 01 April 2011 - 11:45 AM
Probably the rockers, etc. You should do a valve adjustment anyway and after steam cleaning they will be left with little lube so you should apply assembly lube to the rockers, cams, etc.
