Loyale auto tranny fixed, other prob. now
2 replies to this topic
#1 AKIRA
AKIRA
    USMB Reverend
  • 614 posts
  • Jersey Shore (Central) PA
Posted 06 March 2004 - 12:55 AM
It is a 92 loyale with a 4WD 3AT
I think it has finally happened,
1st- works okay except when going up a steep incline is shudders (like it is jumping out of gear) and maybe makes a grinding sound
2nd- works fine I think
And now the worst part:
D- if you start out in drive it refuses to shift out of first, if you put it in drive while moving it acts like it is in neutral, I haven't been able to get it in third at all
in earlier posts I replaced the bad modulator and I found a plastic half-ring piece in the tranny fluid pan, along with a hole in the filter.
do you think it has finally crapped out?
#2 All_talk
All_talk
    1000+ Super USER!
  • 1,093 posts
  • Thorp (Ellensburg)
Posted 06 March 2004 - 03:11 AM
I'll bet its just a stuck governor, I had a similar problem, check this thread:
http://usmb.ultimate...&threadid=10953
And the fix is detailed here:
http://usmb.net/repa...31.34713659.art
If that dosen't do it, I've recently had good luck with some autotrans “snake oil�, the Lucas brand. Fixed up a ’86 K-car that wouldn’t move at all.
Hope that helps
Gary
P.S. watch out for a shim between the cover and the governor, the repair procedure doesn't mention it but mine had one.
#3 AKIRA
AKIRA
    USMB Reverend
  • 614 posts
Posted 07 March 2004 - 03:43 PM
I just test-drived it, that was it, works okay now.
I cleaned the governor and honed the edges.
now the only thing wrong is it shudders sometimes when it shifts out of first, the higher the throttle the higher the chance it happens I think.
thanks man.
