Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
My "NEW" 1988 Subaru GL 4WD
Started by
mr.radon
, Mar 07 2004 05:11 PM
35 replies to this topic
#26
Posted 22 March 2004 - 02:37 PM
A couple of installation pictures:
#27
Posted 22 March 2004 - 02:38 PM
The woofers:
#28
Posted 22 March 2004 - 02:41 PM
The head unit:
Why did I have to stick it out 3/4"?
#29
Posted 22 March 2004 - 03:01 PM
Looks good.
in order for your stereo to not stick out, you have to make or buy an aftermarket faceplate for it like this
#30
Posted 23 March 2004 - 12:41 PM
All right, where do I get the faceplate?
I used my mill to enlarge the opening on the original faceplate so I could get it over the radio. Right now it sticks out 3/4", I put black electrical tape over the sheet metal to blend it in.
Can I use someones face plate as a mold? I can make a copy out of fiberglass and give it back.
#31
Posted 23 March 2004 - 12:54 PM
You can get these at just about any place that carries stereo equipment for autos.
#32
Posted 23 March 2004 - 01:51 PM
If I still lived up there, I would let you borrow mine. I got mine at car toys in Tacoma for 15.99
#33
Posted 24 March 2004 - 04:13 PM
The GOOD:
First gas-up since I swapped trannys. Mostly commuting miles. Put in 12.9g drove 345miles, almost 27MPG? Sound about right?
The BAD:
Cecked oil again and again it dropped. Looked real close last night and there is oil coming from the oil pan drain, will replace that next oil change. However, I still have oil leaking out the front cover. I changed the ruined front oil seal when I pulled it. What else gives? Is it possible to change the cam seals and oil pump seals without pulling that engine?
I only did the front and rear crank seals and the valve cover seals. I read some old post that I should have also replaced a couple of cam seals and oil pump seals? I don't have a manual yet for this model, so I've got no illustration to go off of. Also, I was on-line at parts express, what are the right part numbers and quantities I need? I'm not in a rush, but would like to have all the RIGHT parts when I decide to dive after this problem.
The BAD:
#34
Posted 24 March 2004 - 08:07 PM
If you're still hankering for data, try this guy's website:
http://www.finleyweb...ault.asp?id=142
He has ultralight planes with Sub engines, so his PDF's only have engine and wiring information, but they've been a godsend for me. He has ones for your Legacy as well!
#35
Posted 25 March 2004 - 12:16 PM
The funny thing is I'm a member of the EAA. I used to be a LongEASY driver. Currently I'm building a Cozy Mk IV. Fellow builders have used Sub engines, hence my interest in the make. I won't be ready to fly for awhile, but till I do, my Subaru's will be saving me money so I can afford one.
I think I'm just going to head to NAPA for the parts (oil seals&gaskets) so i can return them if I get the wrong ones.
#36
Posted 20 October 2004 - 09:37 PM
Hey Mr. Radon-- I know it's been awhile, but I am so impressed by your not only your know-how
, but by your diligence in updating this board for newbies like me. Changed my first set of timing belts, oil pump, water pump, cap/rotor, etc. this weekend and it was a blast. I now have somewhat of an idea how much work you did. It would have taken me months to do that job. Maybe some day.
Anyways, just wanted to give you a shout-out and let you know "job well done".
