Subaru engine mated to a Jeep Tranny?
9 replies to this topic
#1 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 09 June 2011 - 12:09 AM
wondering if anyones seen a Subaru engine mated to a Jeep tranny and transfercase like a 90s trans ??
#2 bill hincher
bill hincher
    USMB is life!
  • 191 posts
  • Toledo,Ohio
Posted 09 June 2011 - 07:08 AM
that should be the A-15 ? from asian ?
its the same as the R 150 front housing, but I beleve the input shaft is much longer, a spacer plate would have to be built to allow the use of the current bellhousing to accept it, but it can be done
#3 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 09 June 2011 - 07:58 AM
so a spacer may do it? I could do that , starter seems may be a issue
#4 bill hincher
bill hincher
    USMB is life!
  • 191 posts
  • Toledo,Ohio
Posted 09 June 2011 - 09:12 AM
no man, Its a direct bolt up, the only difference between the A 15 and R 150, 151, 154 is the input shaft length
they all share the exact same bolt pattern, thats why I included the bolt pattern on the original bellhousing, now all thats required is a spacer, or a new housing could be cast from the original pattern to include the length
#5 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 09 June 2011 - 10:50 AM
so your toyota adapter will work on a jeep
#6 bill hincher
bill hincher
    USMB is life!
  • 191 posts
  • Toledo,Ohio
Posted 09 June 2011 - 11:24 AM
yes, it will bolt up but you are responsible to find the throw bearing and clutch disc
#7 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 09 June 2011 - 11:39 AM
how much for the bellhousing to adapt a EJ22 to a 95 Jeep Grand cherokee manual tranny ?
#8 bill hincher
bill hincher
    USMB is life!
  • 191 posts
  • Toledo,Ohio
Posted 09 June 2011 - 11:58 AM
its not that easy
there is a lot of attention to detail to design a functional bellhousing to a given transmission/engine combination
pilot bearings, throw out bearings, throw out bearing holders, custom disc's
everything has to work together
If you want to invest your time, I would be glad to help you
#9 86hatchback
86hatchback
    USMB Regular
  • 129 posts
  • Portland Oregon
Posted 13 June 2011 - 12:10 AM
I'm pretty sure the gear trains are interchangeable with those transmissions. You can use a Toyota g52 gears on the jeep ax5 main shaft. I know for sure the fifth gears swap I'm pretty sure the gears will fit the main shaft as well. I would assume that the ax15 and R series transmissions are the same way.
#10 bill hincher
bill hincher
    USMB is life!
  • 191 posts
  • Toledo,Ohio
Posted 13 June 2011 - 06:40 AM
yeah, for all the trouble its better just to stay with the Toyota trans, but each to his own, the versitility is built into the housing
