Edited by willd, 10 June 2011 - 02:31 PM.
additional info
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
84 GL oil leak
#1
Posted 10 June 2011 - 02:25 PM
#2
Posted 10 June 2011 - 02:49 PM
RV
#3
Posted 10 June 2011 - 03:04 PM
#4
Posted 10 June 2011 - 04:02 PM
the hose is most likely to be from the coolant overflow tank. the oil that is leaking, is it motor oil or trans fluid??? red=trans.
RV
Only if it's an auto.
Auto or stick?
#5
Posted 10 June 2011 - 04:44 PM
Auto or stick?
It is a stick.
#6
Posted 10 June 2011 - 05:04 PM
If you have a feedback carb there is several lines that run between the intake and solenoid valves. The valves are located near the hood hinge on the passenger side. Feedback or not there is a line that enters the cabin a few inches away from there. Though a little far from the wheel the O2 sensor wire is a possible culprit (feedback only). What ever it is should be easy to I.D. and hook back up. Just find the barb thats missing the hose.There is a hose dangling just next to the passenger side front wheel.Where is this coming from and where should it go? Is it possible I have a vacuum hose that has fallen off and needs to be reconnected?
Ive never seen an EA81 w/the tank unless its been added, and even so the overflow should be on the driver's side.the hose is most likely to be from the coolant overflow tank
Sounds like the rear tranny seal. It would require you to pull the drive shaft out to replace it. Easy job but if you arent really leaving big spots I wouldnt be too worried about it. Check the level and watch for spots.Dripping right at the back where the drive shaft leaves to head to the rear wheels.
Edited by ihscout54, 10 June 2011 - 05:16 PM.
"sounded" rude in reply
#7
Posted 10 June 2011 - 05:10 PM
RV
#8
Posted 10 June 2011 - 05:21 PM
Haha sorry didnt mean to sound rude in my reply! I guess Ive been reading too many of G.D.'s posts.good call, i mustve been thinking ea82 while simultaneously not paying close enough attention. thanx for clearing that up
were still on topic
#9
Posted 10 June 2011 - 07:11 PM
#10
Posted 10 June 2011 - 08:19 PM
