Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
micrometer
#1
Posted 25 July 2011 - 07:49 AM
Seems to be pretty handy
#2
Posted 25 July 2011 - 09:43 AM
#3
Posted 25 July 2011 - 10:47 AM
#4
Posted 25 July 2011 - 12:32 PM
Edited by GeneralDisorder, 26 July 2011 - 01:22 AM.
#5
Posted 25 July 2011 - 12:38 PM
I use a digital caliper most of the time but I use vernier (metric) Mic's. Anything that needs to be measured in tenth's I don't trust digital unless it's expensive like Starett and Mitutoyo, etc and I've calibrated it against a standard.
I was asking on the garage journal yesterday about this, my digital caliper does like
#6
Posted 25 July 2011 - 02:08 PM
I just backed out because it took so long to type..
Anyways what I was going to say was I was asking on Garage journal yesterday about if I could of used my digital caliper instead of the micrometer but given the limits in the FSM I was better off with the mic instead.
I don't do anything serious with my caliper because it seems to vary sometimes when closing back to zero.. I do use it if I come up to some large size nut that I'm unsure of the size.
the one I have is also a vernier mic but I might pick one up in metric later.. I just can't see using it much after doing the valve adjust
#7
Posted 25 July 2011 - 09:53 PM
For the most accuracy you really need a metric Mic. You can convert back and forth but it's a pain. Mitutoyo is my preference for quality and cost.
it isn't that difficult to convert from metric to "english" (standard). just take your metric dimension and divide by 25.4 or multiply by .03937. if you want to convert from standard to metric just reverse it , multiply by 25.4 or divide by .03937. it reall isn't that bad. yes , Mitutoya is a very good brand , as are Starrett. i'm a machinist and most of my precision tools are Mitutoya's. they're a little costlier than your generic brands but they're well worth the extra bucks. curtis
#8
Posted 26 July 2011 - 12:33 AM
A few notes... Never store a caliper or micrometer completly closed. If it really is a super critical measurement with very tight tolerances, the temp these things are calibrated at is 68 degrees, There isnt anything that has that kind of tolerances that we work with, but its just a point of information.
You can use a feeler gauge to check the calibration on these tools as the std. Surprisingly feelr gauges are dead on as far as tolerances.
#9
Posted 26 July 2011 - 01:19 AM
#10
Posted 26 July 2011 - 06:06 PM
Converting is fine and dandy if the measureing device has enough inherent resolution to convert - when going from standard to metric it's important to remember that a thousandth of an inch (.001") is still over 2.5 hundredths of a millimeter (.0254 mm). Since most everything in a Subaru engine is measured on the hundredths of a mm scale.... having a Mic. that reads in thousandths of a mm is preferable for accuracy and simplicity. The shims for valve adjustment are availible in .01 mm increments (or was it .005 mm increments?) in any case it's just easier to stay metric the whole time. It prevents errors from creeping into your calculations.
That also goes for torque which is in newton-meters.
