Help me hack my ignition switch.
15 replies to this topic
#1 fattie
fattie
    New User
  • PipPip
  • 21 posts
  • maine
Posted 02 August 2011 - 06:40 PM
it sticks and its really annoying. any tips or tricks to get it working a little better till a replacement can be found ? screw driver ? lube ? BFH ? thanks
oh yea , 86 brat.
#2 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 02 August 2011 - 07:18 PM
I might have an ignition switch...
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,936 posts
  • Portland
It sounds like the ignition *lock* has a problem, not the *switch*.
Remove the lock, take it to a locksmith, and have it rebuilt and new keys made. (in the meantime - turn the switch with a screwdriver)
Replace the switch with an OEM one from the dealer when you get the lock back - about $25.
#4 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 02 August 2011 - 07:21 PM
What part number do you need?
#5 fattie
fattie
    New User
  • PipPip
  • 21 posts
  • maine
Posted 02 August 2011 - 08:14 PM
i meant lock , i just call it a switch. im not quite sure how to take it apart. are there any how-to's on here ? i tried searching but it kept saying no results.
#6 GeneralDisorder
GeneralDisorder
  • 21,936 posts
  • Portland
Posted 02 August 2011 - 08:28 PM
Pull the column covers and it should be obvious.
#7 81EA81
81EA81
    Eat, Live, Breath Subaru
  • 387 posts
  • Spokane,WA
Posted 02 August 2011 - 08:43 PM
Maby try a little WD40, It dose more then you think. I just did this a few weeks ago.
#8 GeneralDisorder
GeneralDisorder
  • 21,936 posts
  • Portland
Posted 02 August 2011 - 09:15 PM
You don't want to use WD-40 - it will evaporate. You need to use graphite. They make it in powdered form as well as a liqufied style that flows easily.
#9 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 03 August 2011 - 07:31 PM
Our locksmith swears by tri-flow.
#10 Redcap
Redcap
  • 335 posts
  • Lewis County, WA
Posted 03 August 2011 - 10:54 PM
Tri Flo is awesome stuff.
#11 man on the moon
man on the moon
    Subaru Fanatic!
  • 609 posts
  • Denver
Posted 04 August 2011 - 12:42 AM
You could always take the locking mechanism out and wire a finger operated switch somewhere...
#12 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 04 August 2011 - 01:16 AM
O.o like a push button start? I have wanted to do this with my car for quite some time :) I think itd be awesome!
#13 GeneralDisorder
GeneralDisorder
  • 21,936 posts
  • Portland
Posted 04 August 2011 - 12:21 PM
You still need a key switch or several toggle switches to turn on and off the accesory and ignition power circuits - besides just the push-button for the starter. And you *should* install a relay to run the starter as well as relays for the accesory and ignition circuits if you are going to do that. Replacing the key switch with a push-button and seperate power circuit switches is not something I would reccomened unless you are well versed in electrical work. That's not a small or particularly simple task.
#14 el_freddo
el_freddo
  • 854 posts
  • Lancefield, Vic, Aust.
Posted 04 August 2011 - 12:46 PM
^ Plus on top of what GD has said you also need to work out a way to safely disengage the steering lock - you don't want that to engage halfway around a corner!!
Cheers
Bennie
#15 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 04 August 2011 - 01:23 PM
O.O
Wont be doing that anytime soon... :lol:
I think Ill stick to eventually (after FM swap) having electric start/keyless entry
#16 fattie
fattie
    New User
  • PipPip
  • 21 posts
  • maine
Posted 04 August 2011 - 03:28 PM
well all i had on hand was " lock de-icer with lube" in the little aerosol can. seems to work alot better till i can get it really fixed. ill look for the spray graphite. thanks
