88 subaru gl rear wheel bearing
9 replies to this topic
#1 derekdee
derekdee
    New User
  • PipPip
  • 27 posts
  • SLC
Posted 03 August 2011 - 10:58 PM
Hey everyone. I need to replace a rear wheel bearing on my GL. Was hoping to order the part prior to ripping it apart. Does anyone know whether the bearings are a kit/assembly or sold as separate inner and outer bearings? I noticed the older models are cone shapped bearings, yea? Sorry, I'm looking at the hayne's manual and it bounces back and forth to cone shaped and a bearing assembly, can someone clarify or drop a part number? Thought about running to the pick and pull, but all the GL's in there have over 160k on them, and thats where I am with the oem bearing. I already replaced both fronts, the noise is killing me.. Thanks guys.
#2 The FNG
The FNG
    USMB is life!
  • 298 posts
  • Goldendale, WA
Posted 03 August 2011 - 11:15 PM
BECK/ARNLEY Part # 0513807
From Rockauto.com and they quote $50.79 I am not sure, but it does not look sealed. It says it is for 4wd rear (you didn't specify) and it is the all in 1 bearing.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,334 posts
  • Portland
Posted 03 August 2011 - 11:42 PM
There were three or four designs over the years - they are all equivelent and interchangeable though.
#4 SoobDood05
SoobDood05
    USMB is life!
  • 207 posts
  • Klamath Falls Oregon
Posted 06 August 2011 - 02:26 AM
I recently replaced mine, its a bearing that requires to be pressed in,and taken out with gear puller, but it is not a sealed bearing.
#5 GeneralDisorder
GeneralDisorder
  • 20,334 posts
  • Portland
Posted 06 August 2011 - 02:51 AM
You don't need a press :rolleyes:. A little creative work with a brass drift and some of the old bearing peices to drive in the new one is all that's required.
#6 The FNG
The FNG
    USMB is life!
  • 298 posts
  • Goldendale, WA
Posted 06 August 2011 - 08:49 AM
You never specified 4wd or not, but regardless this thread should be of some help http://www.ultimates...ad.php?t=112226. It is posted in the USRM under the tranny and axle part. Have fun.
#7 derekdee
derekdee
    New User
  • PipPip
  • 27 posts
  • SLC
Posted 06 August 2011 - 07:12 PM
It's 4wd. Drivers rear. The assembly is most likely trashed, so I'm thinking I will hit up the pick and pull. If not, suggestions... Is this job easier than the fronts? I did both of em about a month ago, sucked.
#8 GeneralDisorder
GeneralDisorder
  • 20,334 posts
  • Portland
Posted 06 August 2011 - 07:57 PM
I would say it's slightly harder than the front's if anything. Though I do bearings all the time so neither is any real big deal to me..... but in the rear the bearing assembly all comes out through the backside of the pocket - and there is a big ring nut that if you don't have the special socket for it can be difficult to remove. Otherwise it's about the same.
#9 derekdee
derekdee
    New User
  • PipPip
  • 27 posts
  • SLC
Posted 07 August 2011 - 07:25 PM
Can i purchase this socket somewhere besides the dealership? Saw pics in the haynes manual. Will I need to press the bearings in or can I use the old ones to rubber mallet them in?
#10 GeneralDisorder
GeneralDisorder
  • 20,334 posts
  • Portland
Posted 07 August 2011 - 07:33 PM
Actually you can't get it through the dealer. If you wanted a "dealer" one you would have to order it through Kent-Moore's Subaru service tool department - they manufacture all the tools the dealers use now.
Here's one:
http://www.etoolcart...cketsu-022.aspx
Another:
http://shoptoolsshop...exd.asp?id=1156
Yet another:
http://www.handsonto...ru_p_19042.html
