There are so many to choose from... which one works best and/or easiest? Thanks.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
ea81 valve spring compressor?
Started by
soobiefreak85
, Aug 11 2011 10:46 PM
3 replies to this topic
#1
Posted 11 August 2011 - 10:46 PM
#2
Posted 11 August 2011 - 10:59 PM
With the heads off I use an OLD Snap-On one that looks like a giant C-Clamp - works great. With the heads installed it can be done too. I use an adapter for a compression tester with the schrader valve removed to pressurize the cylinder with shop air (holding the valves closed). I fabbed up something out of a scrap piece of steel I had laying around the shop to lever the springs down and remove the keepers (you do still have to remove the rocker arm shafts). Although this second method works it is sort of a PITA. Much easier with the heads off:) Be advised that there are at least 3 different styles of EA81 pushrods and at least 2 different height of valve springs that I know of. There are also at least 2 different versions of rocker shafts that I have found so far. Not all these parts will play well together in the wrong combinations.
The smaller "overhead" spring compressors work really well too. I end up using those more for older V-8's though.
Although this is made by Mac Tools, mine looks exactly like this one
MAC-TOOLS-VALVE-SPRING-COMPRESSOR
Edited by Crazyeights, 11 August 2011 - 11:11 PM.
#3
Posted 12 August 2011 - 02:22 PM
I like how that one is assembled wrong but easily changed.
Thats the kind I use on all Subaru heads and it works great.
#4
Posted 12 August 2011 - 11:19 PM
Great thanks guys!
