I have a noise coming from the drivers side front tire when I apply the brakes. My only guess is that the brake pad is so far worn down that its just pressing metal against the roter or whatever it does...heh.
My question is...are there any other things that would make this sound when you press on the brakes? Or is my guess most likly correct?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Noise coming from drivers side front tire
Started by
mattocs
, Mar 11 2004 06:06 PM
5 replies to this topic
#1
Posted 11 March 2004 - 06:06 PM
#2
Posted 11 March 2004 - 06:14 PM
depends on the noise, but it is worth getting checked out immediately. not too wise to ignore noises coming from the front end...
#3
Posted 11 March 2004 - 07:37 PM
Dont some of the newer cars have wear sensorsthat make noise?Describe the noise to us that helps.
#4
Posted 11 March 2004 - 07:45 PM
But it could be a wheel bearing too.
Jack it up and spin it and rock it for play. Then pull the wheel and inspect the brake pads. Should tell you right there.
#5
Posted 11 March 2004 - 07:48 PM
What about turning? That could be a loose gasket on the axel...forget the exact name of it. However I agree that it is probably a brake pad. If you end up changing it yourself, let me know, I am interested in attempting a brake job on my 1993 legacy just to replace the pads.
#6
Posted 12 March 2004 - 01:15 AM
Eop, you really ought to replace the rotors at the same time - o rat least have them resurfaced. You will run into premature problems if you replace only the pads.
Btw, brake job is quite easy, and there will be plenty of support from this site
