95 Impreza L - No cranking
6 replies to this topic
#1 sabreofsd
sabreofsd
    New User
  • Pip
  • 5 posts
  • Springfield
Posted 20 August 2011 - 02:17 PM
Hey Folks,
So after coming back from being away on a business trip, my 95 Impreza L will not turn over. Things I have tried/checked:
Checked all fuses
Jumpered the clutch switch
There is 12V getting to the starter
I've done a ton of searching, so I've come to think it's one of two things:
The ignition/main relay - I'll replace it with either this cool hack or this replacement.
The starter solenoid - I'll get the rebuild kit.
BTW, where is the Ignition/main relay? I see three relays above the fuse box in the driver foot well, but nothing that looks like what I have seen in other posts. Anything else I should check?
Thanks!
#2 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 20 August 2011 - 07:22 PM
Does it click when you try the start position?
I would bet you need a battery or terminal on the positive is corroded.
#3 lmdew
lmdew
    _______
  • 3,728 posts
  • Colorado Springs
Posted 20 August 2011 - 09:43 PM
Your miltimeter will lie to you unless you are checking the circuit under load. I bet if you put your meter back on the starter positive terminal and then have someone try to start it the voltage will drop like a rock.
If there is no drop at all, the contact is not closing in the starter.
Check out some of the training at www.brighterideas.com
#4 sabreofsd
sabreofsd
    New User
  • Pip
  • 5 posts
  • Springfield
Posted 21 August 2011 - 01:24 PM
A couple more details:
There is a relay click when I turn the key to start, but the starter is definitely not moving.
I tried to reaplce to the battery (just in case... it was old anyway) and nothing has changed.
When I tested the voltage going to the starter, it was under load (while I was trying to turn it over).
#5 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,042 posts
  • Honolulu HI
Posted 21 August 2011 - 01:31 PM
Do you hear the starter's solenoid click when you turn the key?
#6 lmdew
lmdew
    _______
  • 3,728 posts
  • Colorado Springs
Posted 21 August 2011 - 05:02 PM
If the voltage was the same before and during your start attemp, the starter solenoid did not close (no load) which is why the starter did not turn over the motor.
Either bad contacts or the control circuit, the small clip on wire to the starter is not getting voltage.
#7 sabreofsd
sabreofsd
    New User
  • Pip
  • 5 posts
  • Springfield
Posted 22 August 2011 - 10:10 PM
Nope, no clicking from the solenoid :(
Imdew: What's the best procedure to check the control circuit? I've tried finding the manual for this car, but every once I download is missing the ignition section :(
