Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Dual Hitachi 26/30 vs Weber 32/36 on an EA71
#1
Posted 26 August 2011 - 06:57 AM
#2
Posted 29 August 2011 - 07:18 PM
#3
Posted 31 August 2011 - 03:14 PM
single weber will be easier to set up and probably a little more economical but the twincarbs will look cooler.
#4
Posted 31 August 2011 - 05:57 PM
Heaps of porting and polishing to heads and manifolds.
Lightend flywheel.
Fully ballanced
Cam grind
Pretty much the works.
I have a dual carb manifold and also a single carb manifold that takes the larger EA81 hitachi.
Flow should not be a problem for either setup.
Like every greedy person I want good top and low end power.
So far as I have read, it would seem that the single weber would give me better low end and the duals would give better top end.
I would like to test this theory with some of you guys who have one or the other.
I would try both myself but I only really have the cash and time to complete one of these setups.
Cheers
Dirk.
#5
Posted 01 September 2011 - 04:21 PM
Real nice low and midrange, no top end but that's most probably due to the manifold and heads.
I think the weber's good for 120hp or so, but the manifold is narrow and has 2 sharp 90 degree bends which is not good.
#6
Posted 02 September 2011 - 12:20 AM
#7
Posted 02 September 2011 - 12:47 AM
the 26/30 for the hitachi refers to the throttle plate size,thus two 26/30's are accually 52/60 total carb bore. compare this to the webber 32/36 and then do the math. hope this helps
Not really. spell it out for me.
#8
Posted 02 September 2011 - 12:52 AM
I've just got a standard ea81 with 32/36 weber atm.
Cool. Thanks.
The other apsect is that the long manifold promotes good torque. The dual carbs technically shorten the manifold lengths so I could be sacrificing the low end torque for breathier top end power.
I wonder if the boxer design will get the most out of the dual carbs or if the weber is better suited.
I am crrently running the EA81 28/32 carb of a stock Ea71. It feels well matched at the moment. Certainly no benefit to a larger carb without the further mods.
#9
Posted 02 September 2011 - 01:10 AM
Sorry man. Was having a little moment when I wrote that.
I get wnat you are saying but unless I get my heads flow tested I won't know if I can make the most of the duals. Hence the dilema.
#10
Posted 02 September 2011 - 01:15 AM
Not true, as increases are exponential
area = pi x r squared
so for the hitachis (26/30)
3.14 x 13 x 13 = 530 square millimetres for the primary choke
3.14 x 15 x 15 = 706 for the secondary
= 1236 per carb / 2472 for both.
a 52/60 carb would be
3.14 x 26 x 26 = 2123
3.14 x 30 x 30 = 2826
which would make total area 4949 square millimetres
32/36 is 804 + 1017 = 1821
#11
Posted 04 September 2011 - 01:46 PM
1. On a non turbo intake fuel/air system, the cylinder volume creates the vacuum in the intake thus sucking the fuel/air mix at the carb(s).The smaller the carb., the less availible mix=longer time to fill the cylinder=less acceration(i.e.resrictor plates in NASCAR).The larger the carb.( or # of carbs.) more volume of fuel/air=quicker acceleration(i.e.drag racing,six-pack hemi's,etc..)
2.Torqe is made by the the ratio -fuel/air to comrpession.The more fuel/air mix available, and the higher the mix is compressed,the bigger the bang thus more torque.
Now with that being said;the dual hitachi would be the choice,,,,BUT
,,,,hitachi's are hiachi's and chasing problems one is often a headache and two=weeks of nightmares.Having run duals on stock EA-71s for over 100,000
miles i've been there.
I would suggest that you try each set-up and see which one fits for you
