dashboard buttons backlight
7 replies to this topic
#1 turboguzzi
turboguzzi
    USMB Regular
  • 164 posts
  • italy
Posted 22 September 2011 - 11:40 AM
Taking care of the usual subbie things on my new 95' Leg,
Sorted the "steering pump leak" last weekend that turned out to be just a leaking resevoir at the seam...(round type). de-crimped it, crimped it back with plenty of RTV at the joint, all nice and dry now :)
Next on the list are: the usual oil pump seal thing and one CV joint, peasy, parts on the way.
Now then, the one thing that looks way more difficult to sort, (at least for me) is the missing back light in all the little dashboard buttons, i.e. A/C, heating, fog light, etc. Just bothersome at night when you need to press on them...
The instruments lights are fine BTW.
They were all functional some weeks ago, but not anymore.
I sure checked all the fuses in passenger and engine bays and all are OK. so not THAT simple...
Is there a relay that controls these to look for?
any other ideas?
Grazie mille!
TG
#2 Mike104
Mike104
    Subaru Fanatic!
  • 731 posts
  • N KY
Posted 22 September 2011 - 11:44 AM
Could be the bulbs.
This post covers the Heat control buttons and is similar for the other switches:
http://www.scoobymod...t-t91.html?t=91
Here is one for switches that is similar for most:
http://www.scoobymod...bulb-t3615.html
#3 turboguzzi
turboguzzi
    USMB Regular
  • 164 posts
  • italy
Posted 22 September 2011 - 12:17 PM
Thanks mike, but all of them working a few days ago and then ALL of them burnt out, at once? very very unlikely.... winning the lottery type of chance, IMHO
ill keep scratching my head :)
#4 Mike104
Mike104
    Subaru Fanatic!
  • 731 posts
  • N KY
Posted 22 September 2011 - 12:38 PM
There is a device called an Illumination Control Module that controls those that may have gone bad.
#5 turboguzzi
turboguzzi
    USMB Regular
  • 164 posts
  • italy
Posted 22 September 2011 - 02:36 PM
well mike, reading some posts about it, sounds like it.
doesnt seem to be more than a simple relay, just the location a bit elusive ?
is it next to the steering wheel in a 2nd gen leg?
sounds like i am going treasure hunting this weekend
TG
#6 the3rsss
the3rsss
    USMB is life!
  • 203 posts
  • vineland
Posted 22 September 2011 - 10:04 PM
All but one of those bulbs were burnt out on my 99 obw. I tried to get the complete bulb and base but had no luck. I got mini 12v bulbs at radio shack. Had to solder out the old bulb. The new bulbs have long wire leads that need to be bent into place , trimmed and soldered. Not hard ,just a pita.
#7 Durania
Durania
    Elite Master of the Subaru
  • 3,120 posts
  • Crossville, TN
Posted 24 September 2011 - 11:44 PM
The bulbs do not need to be soldered, just looped back into the base as they were from the factory.
#8 turboguzzi
turboguzzi
    USMB Regular
  • 164 posts
  • italy
Posted 25 September 2011 - 06:32 AM
turns out that i might be wrong..... the headlapmp dipper regulator backlight does work....
not sure it means that it runs through the same module as the A/C, fog etc, but it might
a quick check revealed quite a few burned lamps in the push buttons, os better rule that out first.
