mickytrus Posted March 14, 2004 Share Posted March 14, 2004 Separating the engine from the bell housing standard trans...... Is there just 4 bolts holding the engine to the bellhousing? If there are just 4... which I think is true Any tricks for separating the engine from the trans after the four bolts are taken out? I removed the two bolts on each side of the engine motor mounts, which bolt up into the block out... so for easy sliding.... Thanks, Micky Quote Link to comment Share on other sites More sharing options...
WJM Posted March 14, 2004 Share Posted March 14, 2004 4 bolts, yep. Id take the engine trans mounts loose from the crossmember from under the car...then lift the engine, and use a jack to lift the trans, to get the engine mounts clear of the crossmember...then, separate the engine from the trans enough to get a screwdriver in between, and just pry the two apart. Make sure to not let the engine slam into the radiator if its still on the engine bay..... Quote Link to comment Share on other sites More sharing options...
