CNY_Dave Posted October 15, 2011 Share Posted October 15, 2011 I've been dodging fixing an emissions code, P1443. Dove into it today, research showed it was most likely the drain valve, and if you connect the green connector under the dash, all solenoids and the fans are supposed to cycle. Was getting power, it didn't cycle, I managed to get it apart and the round slider was stuck in the bore. Wasn't rust, the plastic in the bore had swelled a bit. Poked around, found the hex part of an old clutch pushrod from a '67 GTO I had years back was a tight fit in the loose part of the bore. Chucked it in the drill press, bored the bore just a skosh, it's like new! Dave Quote Link to comment Share on other sites More sharing options...
Scomber Posted October 15, 2011 Share Posted October 15, 2011 Congratulations. Drain what? And what oracle do you consult when you do research? Scomber Sanctus Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 16, 2011 Author Share Posted October 16, 2011 There is hose/filter/valve assembly just ahead of the rear bumper on the right side, part of the evap system. I just followed the diagnostic in a downloaded manual. Dave Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 16, 2011 Share Posted October 16, 2011 it alll depends on the year!!!!! Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 16, 2011 Author Share Posted October 16, 2011 Forgot I don't have a sig- 2003 LL bean with the H6. Dave Quote Link to comment Share on other sites More sharing options...
the3rsss Posted October 17, 2011 Share Posted October 17, 2011 God im envious. I had a po443 evap code that took me 2mths, a new ecu, and alot of work to find my problem. Turned out a mouse ate thru the drain valve to ecu wire. This shorted out the ecu (opened it up and one of the ic's were toasted). I didnt even try to fix the wire. just ran a new one from the ecu back to the drain valve. Glad yours was an easy fix. Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 17, 2011 Author Share Posted October 17, 2011 I hate mice. So far only critter that has chewed on my wires is a groundhog the dog chased under the car, and it climbed all the way up to just under the windshield. I think since I park outdoors and there is a big cozy garage nearby, they much prefer the garage. Dave Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 21, 2011 Author Share Posted October 21, 2011 Valve still works, code is back. So, more than one thing was broken... Dave Quote Link to comment Share on other sites More sharing options...
