Rear coilovers on 84 Brat?
stephen115
How do I do that?
Support rear on jacks, remove wheels.
Remove the lockbolt from the tosion tube, it's underneath, right at the end of the tube.
Remove the 3 bolts holding the torsion arm to the trailing arm.
Slide torsion bar out, rotate it one tooth, reinstall.
repeat for other side.
If it drops it too much, you can then use the adjuster bring it back up.
