Idasho Posted October 20, 2011 Share Posted October 20, 2011 So Ive got a leaker. The front oil seal on the rear diff is loosing gear oil. Just enough to worry me, and to splash gear oil onto the exhaust pipe. Makes for a wonderful odor:D Question though. My shop manual doesnt cover replacement of this seal. I have the exploded diagram, but no info. Does this pinion use a "self locking" one-time-use nut, and what torque values must it be set to on reassembly? Thanks for any help! Quote Link to comment Share on other sites More sharing options...
Idasho Posted October 22, 2011 Author Share Posted October 22, 2011 Any help here? I did find the seal. Dealer had one in stock, $16 Quote Link to comment Share on other sites More sharing options...
coxy Posted October 22, 2011 Share Posted October 22, 2011 The real issue is not the locknut but does it use a fixed spacer and shims or a collapsable spacer for the pinion shaft bearings if the latter it can be an issue when you undo and retighten the nut. Red loctite or the equivalent permatex product can allow reuse of such nuts if needed. Quote Link to comment Share on other sites More sharing options...
Idasho Posted October 22, 2011 Author Share Posted October 22, 2011 Thanks for the response! According to my shop manual it uses fixed spacers and shims. So if I mark the location of the nut prior to removal, and lock9tite it back in the same location after replacing the seal everything should be good to go? Quote Link to comment Share on other sites More sharing options...
