98 OBW radiator swap out
12 replies to this topic
#1 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 20 October 2011 - 11:26 AM
I need to replace my radiator in my 98 OBW. I read through the search archives, and could only find someone, who said that two bolts hold the radiator in. Also said that it is not necessary to remove the dual fans to remove the radiator. If all this is correct, then all that is left, is to remove the rad hoses, and ATF lines. Is this correct, or is there anything else I should know? Thanks!
#2 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 20 October 2011 - 11:35 AM
Hm, I haven't worked on a 2.5L dohc from that era, but all my soobs, the radiator fans are bolted to the radiator. So you can pull the fans and radiator as a unit, but they still have to come off and get mounted to the new one.
Usually it is just the two bolts that fasten the two radiator mounts at the top. The radiator has little pegs with rubber booties that sit into some metal underneath.
One of the harder parts can be getting the ATF cooler lines off. Those hoses seem to really like to get stuck on there good.
#3 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 20 October 2011 - 12:36 PM
Thanks..........good advise........Rooster2
#4 Mike104
Mike104
    Subaru Fanatic!
  • 731 posts
  • N KY
Posted 20 October 2011 - 01:33 PM
Also need to disconnect the fan electric connectors to remove the Rad/Fans as a unit. ATF hoses were welded on! I just cut them and bought new straight hose with new clamps. Worked ok.
Bolts that mount the fans can be rusted. Spray some PB Blaster on there first.
#5 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 20 October 2011 - 01:56 PM
If you cut the ATF hoses, you could just go hose back to the pipes near the starter. I've had the section of ATF pipe that goes underneath/near the battery rust out on a couple of my soobs and dump a lot of precious ATF onto the ground, so I try to pay attention to that area. I believe I used 3/8" i.d. hose for that, which seemed to be a little bit bigger than the likely metric size that is stock, but trying to fit 5/16" id hose onto the radiator nipples was very difficult.
#6 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 20 October 2011 - 04:00 PM
Thanks to all for the good advise. Rooster2
#7 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,010 posts
  • East Coast
Posted 20 October 2011 - 05:06 PM
most annoying part to me is just catching the coolant dumping out.
otherwise it's really easy like already covered. the ATF and radiator clamps are often rusted to the point that reusing is not an option.
#8 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 20 October 2011 - 05:34 PM
One of the harder parts can be getting the ATF cooler lines off. Those hoses seem to really like to get stuck on there good.[/QUOTE]
Would it do any good to spray the ATF cooler lines with PB Blaster the day before trying to remove them from the radiator??
#9 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 20 October 2011 - 05:55 PM
i have done a couple of these. i cut them off unless they relatively new. actually i always try to remove them but i almost always fail and just cut.
to replace you need 5/8" trans fluid hose, ~18 inches, 8 inches for the top hose and ~10 inches for the lower hose.
i read somewhere that the hose costs $2 per foot, so the replacement cost is $3. i re-use the clamps unless they get ruined in removal or look suspect.
#10 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 21 October 2011 - 07:59 AM
Thanks for the hose info. I appreciate it!
#11 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 23 October 2011 - 01:53 PM
For what it is worth, my mechanic showed me how to use a very long straight tip screw drive as a pry bar to push the hose off the rad fitting. He says this approach always works.
#12 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 23 October 2011 - 02:17 PM
glad to hear it. i hate wasting good parts, but i hate wasting time fighting a $2 part even more.
thanks.
of course, sometimes the hose need replacing anyway.
#13 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,058 posts
  • Honolulu HI
Posted 23 October 2011 - 07:10 PM
So? What's the trick? :popcorn:
