Any experience with Paraut oil pumps?
4 replies to this topic
#1 cmill189
cmill189
    USMB Regular
  • PipPipPip
  • 55 posts
  • Salt Lake City
Posted 21 October 2011 - 10:53 AM
So I came across a listing on ebay for a new Beck/Arnley oil pump for $23. I figured someone forgot to type a 1 in front of the 2, so I bought it. What showed up was a Paraut brand. I figured anything is better than the one I just re-installed that didn't meet spec and had gouged rotors.
A second question
I pulled all the covers off when I did belts/seals/etc. Is it possible to slip the drivers-side timing belt off the idler, and then off the oil pump, all while leaving everything else in place?
Thanks for the help.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,704 posts
  • Portland
Posted 21 October 2011 - 12:05 PM
Paraut is one of the OEM manufacturers. If you look at the pump it likely will say Aisin on it. But either way both are Japanese and inter-related brands. A long time ago I bought a Paraut branded pump and it was OEM inside the box.
There aren't any aftermarket makers of oil pumps for EA engines that I have ever seen. So if you got an oil pump at all - it's OEM.
You may be able to do just the drivers side belt - only thing you can do is try.
#3 silverhelme
silverhelme
    USMB is life!
  • 323 posts
  • Republic, WA
Posted 22 October 2011 - 10:21 AM
You still have to pull the center cover but yes you can pull the drivers belt and do the oil pump without pulling the other side.
#4 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 22 October 2011 - 04:48 PM
If it was me, I would pull both belts and check the rollers with it that far apart to make sure I don't have one going bad.
#5 cmill189
cmill189
    USMB Regular
  • PipPipPip
  • 55 posts
  • Salt Lake City
Posted 22 October 2011 - 07:19 PM
All of the timing belt covers were left off when I changed the belts. Both tensioners and the idler were replaced with new as well; the suspected originals were beyond worn out!
Thanks for the help everyone.
