subestyle18 Posted March 14, 2004 Share Posted March 14, 2004 My carb on my 83 gl wagon is in deperate need of a rebuild. Im heading down to the junk yard and picking up another hitachi to rebuild. I am wondering where to buy a rebuild kit for this carb. I have been looking on the net and found a couple sites selling them for around $50 is that a good price. Thanks David Quote Link to comment Share on other sites More sharing options...
rallyruss Posted March 14, 2004 Share Posted March 14, 2004 the most common problem is the worn out throttle shaft bushings. a regular rebuild will not help you with that. check out roobuilders http://www.ccrengines.com/roobuilders/ or a local machine shop possibly Quote Link to comment Share on other sites More sharing options...
subestyle18 Posted March 15, 2004 Author Share Posted March 15, 2004 The reason i was wanting to rebuild was because i know i have a vacume leak at the gasket between the carb and the intake manifold. I thought that if i had the carb off i might as well rebuild it. Also i was having trouble finding a new gasket to replace the old on and assumed it would be included in a rebuild kit. Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted March 15, 2004 Share Posted March 15, 2004 carb good, manifold to carb gasket bad solution: rebuild kit, incluses gaskets, seats, NOT THE FLOAT the GASKET is available separate http://www.oreillyauto.com/B2C/conditionselect.ecatalog?x_0=Y&submit=Continue&vehicle=vehicle0&category=9&group=13&keyword=+&description=+ Add Qty Description Part No. Unit of Meas. Unit Price Core Price Status BORG-WARNER BWD Float 1 per car. CF502B Card $7.29 N/A HITACHI EQPD BRASS 1 YEAR LIMITED WARRANTY * WALKER (WLK) Float 1 per car. 100-138 Card $6.99 N/A 1 YEAR LIMITED WARRANTY BWD Float 1 per car. CF502B Card $7.29 N/A HITACHI EQPD BRASS 1 YEAR LIMITED WARRANTY * WALKER (WLK) Float 1 per car. 100-138 Card $6.99 N/A 1 YEAR LIMITED WARRANTY WALKER PRODUCTS WLK Air Accelerator Pump 1 per car. 764F WLK Needle & Seat 1 per car. 31-651 CHECK CARB # WLK Needle & Seat 1 per car. 31-657 CHECK CARB # WLK Carburetor Base Gasket 1 per car. 1054F CHECK CARB # WLK Carburetor Base Gasket 1 per car. 909F CHECK CARB # WLK Carburetor Kit 1 per car. 151051 Each $18.99 CHECK CARB # 1 YEAR LIMITED WARRANTY WLK Carburetor Kit 1 per car. 15853A Each $23.99 CHECK CARB # 1 YEAR LIMITED WARRANTY Quote Link to comment Share on other sites More sharing options...
