Maximum Tire Size on 15" Rims + 2" Lift?
Hi all! :)
Yes, I did the Search thing and I only got Li'l confused; so I must start a New Thread in order to find the Right answer.
My BumbleBeast has this Setup:
  • Front Suspension: 4WD Subaru Shock absorbers Plus Ford Tempo Coil Springs.
  • Rear Suspension: 4Runner Shock Absorbers plus Honda accord Coil Springs. (that makes a 2" Lift)
  • Fifteen (15") inches Rims.
(Details about my Suspension mods, could be Found here)
So, The Rear became Taller than the Front... But Now I am about to install a SJR 2" Lift Kit for the Front of my Wagon, (More Details here) So my BumbleBeast will be on Level. :D
The Question I Have is This:
Which Size of Tire is the Maximum (Tall & Wide) I can Run on my 2" Lifted BumbleBeast Without trimming?
Now it Runs unlifted on 205/60 R15. I'll Like to know which Tire sizes run on 15" rims, people who has 2" Lifts on their EA82 Subies.
Kind Regards. :burnout:
Edited by Loyale 2.7 Turbo
white words are links
im currently unable to get any pics up w/o a pc at home. you can search my posts/threads. my fenders are cut similar to One Eye's yellow wagon. I will say this tho, I cut my fenders before getting those tires. I origionally had 235/75/r15s and couldnt cut/beat enough to make them fit so all my info is potentially worthless. sorry about that. IMHO if you wanna go bigger and not cut fenders (your car rocks, my car is beat and ugly) i would go taller. others can help out.
hth
RV
What kind of rim are you using?...
Good Question, They're Very Close to Stock offset, but 15" alloys; you can see them in the Picture attached on the link below, or by Clickin' on my Signature; those are in my "BUMBLEBEAST" Subaru.
http://www.ultimatesubaru.org/forum/album.php?albumid=51&pictureid=3242
I have 27 inch tires with a 2 inch lift...
Could I Kindly ask you, Please, to give the Tire's Measurement in the Standard Format? ...
I'm not Sure which size is 27"
Now My Bumble Beast has 205/60 R15
I don't know how to Measure them to tell you if they're 25", 26" or so...
Kind Regards.
to add the Picture's Link
27's are pushing it.... 215/75/15 might be able to fit, but it might rub the fenders under full compression...
a 225/60 or 225/65 probably wont rub and gives you the widest tread that can fit.
i also know that you will have to trim and bash for hours to get a 235/75/15 to fit without rub, lock to lock.
how opposed are you to "massaging" the inner fender well with a BFH? you should be able to get an even bigger size to fit without cutting the finders themselves.
Thanks for the Answer, so 27" are too big.
I'm a Li'l Lost in Translation with This:
...how opposed are you to "massaging" the inner fender well with a BFH? ...
You mean to Hit the inner Part of the car (that is the Floor) to fit a Bigger Tire?
Well... it could be done but a Little in order to avoid deform it to a noticeable way.
Could someone Post Pics, Please; of their Big Tire Setup?
Kind Regards.
215-70-15 is great!!
lots of good a/t tires come in that size.
its big enough. wider without really being too wide,
and tallish without killing trannys or hurting acceleration too much.
i also lean toward medium sidewalls. thats why i went to all the trouble of
getting 15s when i couldve just thrown 27x8.5x15s on, and got the same overall dimensions.
the 215-70-15 is supposed to be 26.85.
with a sidewall a half inch shorter than a 215-75-15.
i wish someone would make some strong, light, affordable 16x6s in 4x140mm.
then id just run 215/65/16s.
6-lug wheels come in 16x6". Redrill to 4x140mm.
Problem solved.
I had to Trim to make these tires fit. ...
Thanks for the Pics, those Tires are Good Lookin' and somehow they're like the ones I Wanna Run on my BumbleBeast.
So, Those are 27" and your Subie has a 2" Lift, isn't it? ...
if so, it looks like Too much Trim for me.
So what Tire size do you Suggest to me? ... 26"? ...
Could 215/65 R15 Work?
use this to help figure it out
http://www.miata.net/garage/tirecalc.html
y hola! amigo, que tal?
I'm running a 205/70 - 15 but it's a 4" lift, no trim. I do rub on maximum lock, just barely. I may be going to a low profile 16" because I can get some really nice rims for cheap. Using that tire size calculator I can find a smaller outside diameter and lower sidewall even though it's a larger inner diameter.
Tengo gusto de visitar Honduras, pero esté peligroso a través de México! (mas o menos, 'babel fish' no esta exactemente, lol)
Thank you...
I already know that 215/65 R 15 Tire will be 26" ... the information I need is if my 2" lifted Wagon will have enough space for those tires without Trimming nor Rubbing.
y hola! amigo, que tal? ...
¡Bien, Gracias! :)
...Tengo gusto de visitar Honduras, pero esté peligroso a través de México! (mas o menos, 'babel fish' no esta exactemente, lol)
Well... Babel fish works somehow like the Google Translator.
You're Welcome to my Beautiful & crazy Country, I hope that you'll Like it! :D
Please, let me Know where you want to Stay, so I can go visit you with my BumbleBeast Subaru :burnout:
Kind Regards.
Kind Regards.
one thing you will have to do with that hammer is flatten the seam in the wheel well, and a bit on the inside so that you can retain a full lock to lock steering.
you can get away with a tad of hammering without anybody noticing anything. like i said, "massaging" :D
