Under-heating
15 replies to this topic
#1 Ever Victorious
Ever Victorious
    Hazard to himself
  • 882 posts
  • Everett
Posted 04 November 2011 - 03:08 PM
EJ22. Driving around town, has normal temp on the gauge, no heat from the heater while at idle but plenty of heat while at RPM's. Never overheats, even if you just let it idle endlessly. On the highway, temp drops to the C line or just above. It will blow heat until the temp goes cold (obviously). Coolant has just been replaced and the system burped. Does not appear to have lost any coolant from the overflow tank since the system was last serviced.
It's acting like the t-stat is stuck open. Any way to confirm that vs. some other cooling system failure that WON'T require me to drain the whole bloody system again?
#2 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 04 November 2011 - 03:20 PM
No heat at idle is a sign of air in the system, sounds like you have a leak.
It does also sound like a stuck open T-Stat, had the same issue on a brand new one a few years ago.
#3 rain_man_rich
rain_man_rich
    USMB Regular
  • 141 posts
  • Grants Pass
Posted 04 November 2011 - 03:24 PM
Had the same issue in a chevy s-10 once. As it turned out, it was a piece of gasket sealant that partially blocked the heater hose.
#4 wtdash
wtdash
    Subaru Nut
  • 1,562 posts
  • N. ID
Posted 04 November 2011 - 03:51 PM
Unfortunately, I also think it's the T-stat. Did you use OEM as recommended on here? The gauge on all my Subies never moves once to operating temp - the opening/closing of the Tstat never is really noticed on the gauge. Everett, WA doesn't get that cold, last I checked.
I also think you have may still have air...but usually that'll cause an overheating issue, in my experience.
To burp:
Once it cools off, take off the rad cap and fill it with 50/50 til full. Then, undo the top rad hose from the Rad on the passenger side and using a funnel or what-have-you, fill it 'til you can start to see it in the hose attached to the engine (coolant cross over pipe). Reattach the hose.
This has always ensured my system is full and w/out air.
GL,
Td
Edited by wtdash, 04 November 2011 - 03:57 PM.
#5 Ever Victorious
Ever Victorious
    Hazard to himself
  • 882 posts
  • Everett
Posted 05 November 2011 - 01:39 PM
No clue. I've owned the car a whopping week. So far I've just done an oil and coolant change, which I always do immediately to any car I buy.
To burp:
And now, for another episode of, EV's Stupid Question of the Day!
... Uhm, won't that hose already be full of coolant and spill all over the place if I take it off?
#6 wtdash
wtdash
    Subaru Nut
  • 1,562 posts
  • N. ID
Posted 05 November 2011 - 05:12 PM
Not stupid @ all....I shoulda/coulda clarified: If the system is full, then
some fluid may spill out and don't bother filling. No place for it to go. :-)
TD
#7 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 05 November 2011 - 11:11 PM
Coolant change .. there is an air buble.
Refill procedure:
remove cap.
With engine running slowly fill radiator.
ONce the t-stat opens (may be some overflow from the radiator) top off radiator.
Put cap on radiator
Fill overflow tank
Drive around block
Allow to cool
Check fluid levels, repeat if needed. If you have to repeat it more then once something else is going on.
Thats the proper procedure for all cars BTW, just people don't do it.
#8 Ever Victorious
Ever Victorious
    Hazard to himself
  • 882 posts
  • Everett
Posted 07 November 2011 - 12:32 PM
Well, it's better, I guess. I now have heat at idle. And at highway speed the temp gauge is no longer *AT* "C". It's just a hair above. :/
#9 wtdash
wtdash
    Subaru Nut
  • 1,562 posts
  • N. ID
Posted 07 November 2011 - 12:34 PM
Do you replace the T-stat??
Td
#10 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 07 November 2011 - 01:10 PM
the gauge is suppose to be in the middle. not at or near C.
something is wrong with the t-stat. and maybe the radiator.
i bet the car was overheating and the previous owner modified the t-stat so it would not over heat.
it could be the head gaskets (look for gunk in the over flow bottle and or bubbles) but probably the radiator maybe the pump.
check the t-stat.
i pulled the t-stat out of a 90 nissan truck once and ran it that way for a year. i never knew a car could run that cool. and the gauge sat on cold almost all of the time.
#11 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 07 November 2011 - 03:33 PM
It actually sounds likt it doesnt even have a T-stat
#12 Ever Victorious
Ever Victorious
    Hazard to himself
  • 882 posts
  • Everett
Posted 07 November 2011 - 07:02 PM
No, as indicated earlier in the thread. I absolutely ahbor dealing with coolant, so I was asking about methods that don't require draining the coolant. Which replacing the T-stat does.
It now, after adding more coolant today, is acting exactly the same way that my Saturn acted when the thermostat was stuck open.
something is wrong with the t-stat. and maybe the radiator. i bet the car was overheating and the previous owner modified the t-stat so it would not over heat.
check the t-stat.
No gunk or bubbles in the overflow tank. None of the other usual symptoms of a head gasket like coolant in the oil, white smoke, overheating, or coolant consumption, as far as I can tell.
So we're pretty much down to t-stat, radiator, and water pump now, eh?
Looks like I get to drain the coolant. Again. That makes me so freaking happy I could puke.
#13 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 07 November 2011 - 07:27 PM
i replaced my radiator recently and i had done an engine swap about 2 years, 25k miles, ago. so i wanted to reuse the coolant. i bought a big flexible bucket or tub (purple) from lowes that holds about 3 gals. put it under the t-stat housing and loosened the lower hose at the t-stat end. i caught almost all of the coolant. then i made my wife strip off her pantyhose and i strained the coolant as i poured it into a couple of 1 gal jugs.
then i gave the pantyhose back. :brow:
#14 Olnick
Olnick
    Ol' Subaru Guy
  • Moderator
  • 3,042 posts
  • Honolulu HI
Posted 07 November 2011 - 07:32 PM
. . . then i gave the pantyhose back. :brow:
You're such a super nice guy John. I hope your wife appreciates you. :)
#15 Ever Victorious
Ever Victorious
    Hazard to himself
  • 882 posts
  • Everett
Posted 07 November 2011 - 08:58 PM
Ok, John, that made me roffle just a little... thanks...
#16 Ever Victorious
Ever Victorious
    Hazard to himself
  • 882 posts
  • Everett
Posted 09 November 2011 - 12:16 PM
Aha! Took a peek under the hood last night after I parked the car in the garage, and found a VERY minute coolant leak. I wasn't noticing it pooling on the floor because it is so minute. It looks like the leak is coming from the driver's side of the radiator.
So now I have TWO excuses to drain the coolant. That's enough to satisfy me.
