EJ25 cam swap question - swap cam or retain cam with head?
3 replies to this topic
#1 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,731 posts
  • East Coast
Posted 07 November 2011 - 03:16 AM
i'm getting used SOHC heads for a friends 03 forester that busted a timing belt.
1. the replacement heads are off an engine with rod knock - which suggests previous overheating and these do sometimes seize cams.
- cam seizure is related to bearing surface on the head or cam?
2. the original engine has never been overheated.
is it better to:
1. swap the original cams into the replacement heads?
2. keep the cams married to the heads they're in?
done lots of EJ swaps, head jobs...but never thought about this...
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 07 November 2011 - 09:06 AM
I would suppose keep the cams together. Minly, because you can remove and install the heads without removing the cams.
This is a relief to anyone who has done millions of ea82's!
I doubt the cams would be affected as much from overheats, being they are farthest from the source of heat, and are made of harder metals.
#3 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
  • Pittsburgh suburbs (NE)
Posted 07 November 2011 - 09:25 AM
I'd inspect (mostly looking for bad burnt oil evidence) and then leave the cams inplace. They are matted/worn in by this time and match the head.
And as pointed out are easy enough on a SOHC to change later if necessary.
Now if its ugly under that valve cover I might rethink it.
#4 idosubaru
idosubaru
  • 23,731 posts
  • East Coast
Posted 07 November 2011 - 10:19 AM
that's tough, i hear you. it's just hard removing the known good, never overheated parts when i have seen cam seizures.
i'll probably keep them with the head, but save the original cams just in case.
