Anyone know the P/n's of the bushings needed to tighten up the shifter in a 93 loyale front drive 5mt. It would help if I call em in instead of going after work. One other quick question. The electric fan hasn't come on since we put the car back together. I jumped it out this weekend and it ran. I now have to check the sending unit. The question is should it come on with the A/C compressor or just the temp switch on the radiator. Thanks
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
EA82 Shifter Bushing P/N's ?
Started by
bigjimd
, Nov 21 2011 12:20 PM
6 replies to this topic
#1
Posted 21 November 2011 - 12:20 PM
#2
Posted 21 November 2011 - 02:18 PM
If yours is an EA82 with two Fans, one electric and one Fixed, driven by the Pulley; then the electric one should turn on when:
Kind Regards.
- The A/C is activated.
- The Engine's Temperature reaches slighty above the Middle.
Kind Regards.
#3
Posted 21 November 2011 - 08:36 PM
Thanks for the info. I thought it was supposed to work that way. Sorry about the first question. When I got to the dealer I found out all the different P/N's and realized what a stupid question I had asked.
#4
Posted 22 November 2011 - 08:07 AM
Daughters going out of town so wanted to tighten things up for here as she still isn't real comfy with the 5speed so I used some insulation off a piece of 12/2 cable. It took out most of the slack. The worst one is at the shifter to shift rod junction. I know it won't last but made a big difference. We have some stout plastic thin wall hose here at work I'm going to try and find something that will work better than the insulation sleeve. Can't get parts till after the holiday. Plus I just like homegrown better.
#5
Posted 23 November 2011 - 08:30 PM
there was a post about using some nylon washers/bushings or someting for this, let me see if i can find it! its like a $6 fix!
#6
Posted 23 November 2011 - 08:32 PM
#7
Posted 23 November 2011 - 11:35 PM
Thanks a bunch!! Just what I need. An ideal solution, should last forever. We have some types of high tech tubing at work and was going to try and make the bushing from that but couldn't find the right size. Besides I like the OP's design better. Just noticed something on the parts diagram print out I got from the dealer. It shows a little spring that goes to the bracket that bolts to the trans. I saw that on the car but didn't see where the other end hooks. Does anyone by chance have a pic of how that springs mounts?
Edited by bigjimd, 23 November 2011 - 11:49 PM.
