Swap the Fan / Dead Fan Clutch \ Retrofitting?
70 replies to this topic
#51 zukiru
zukiru
    MPFI is fun.
  • 1,214 posts
  • Oak Grove, AL
Posted 27 November 2011 - 01:32 AM
Nice score!
Infact, I wouldn't mind one myself.
Edited by zukiru, 27 November 2011 - 01:36 AM.
#52 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 4,834 posts
  • Roatán, Honduras.
Posted 28 November 2011 - 06:40 AM
The Toyota Prius Twin Fans...
Posted Image
...Fits, because they're just...
Posted Image
...2¼ inches thick and the EA82 has...
Posted Image
...2½ inches of free space.
#53 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 28 November 2011 - 06:46 AM
Yesterday I Placed everything Together...
Yes the Prius Twin Fans Fits, but you Need to remove the Power Steering's Pump Reservoir Tank to Slide the Prius Fans in its place.
Posted Image
Posted Image
#54 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 28 November 2011 - 07:07 AM
The only thing I Really Dislike about that, is the fact that it only leaves ¼ inch of free space, between the Spinning Waterpump's pulley and the Prius fans' back.
That complicates my idea to simplify things in the engine. :(
Even I Removed the covers from the timing belts to simplify things when I need to change one.
Posted Image
#55 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 28 November 2011 - 05:40 PM
The Prius fans works but the fact that it only leaves ¼ inch of free space demotivated me, So I was able to Go today to the Junk Yard where I Purchased the Prius Twin fans set and I Returned it; they gave me my money Back.
#56 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 29 November 2011 - 03:49 PM
So, after searchin' for a good Slim aftermarket Electric fan, Local mechanics suggested me to use the one I Obtained: A Slim 12" Electric fan, very powerful & Fast.
I Obtained it on a Local car parts' Store, is "UniPoint" Brand:
http://www.unipoint.com.tw/
Edited by Loyale 2.7 Turbo, 30 November 2011 - 05:20 PM.
to add the web link.
#57 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 30 November 2011 - 05:21 PM
Here, The New Fan's Box:
Posted Image
Here, the Fan Details & Measurements:
Posted Image
and Here, the Fan Characteristics:
Posted Image
#58 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 30 November 2011 - 11:24 PM
When I took out the Honduran-Made double row Radiator, I Noticed that its paint was almost gone and had some scratches, as you can see below:
Posted Image
This is how it looked like after being in its place for more than ten years of non-stopping hard work
and it still worked fine, but I Took it to the Radiator Shop for Maintenance,
so they could check for Leaks and repair if needed.
#59 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 30 November 2011 - 11:30 PM
I Tested the New Slim Fan there, at the Radiatoir Shop...
Posted Image
Posted Image
You can see the Original Subaru A/C fan, next to the New slim fan.
#60 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 30 November 2011 - 11:36 PM
I Went to pick up my Repaired & Repainted Radiator today, yes it had a minor leak due to a minor hit done by the old pulley-driven fan, when it failed...
Now it Looks like New! :burnout:
#61 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 30 November 2011 - 11:41 PM
This is How I Bolted-on the New Slim electric fan:
Posted Image
I used two thin pieces of metal plate (1/2" wide X 1/8" thick, one on the left side and one on the right side)
between the radiator and the fan's mounts to act as a washer for the Screws and spacer for the fan at the same time.
Edited by Loyale 2.7 Turbo, 30 November 2011 - 11:45 PM.
to add the blue measurements
#62 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 30 November 2011 - 11:47 PM
This is how Both fans Looks Together:
Posted Image
Here the Old Subaru one just needs its screws, but is in its original place.
#63 zukiru
zukiru
    MPFI is fun.
  • 1,214 posts
  • Oak Grove, AL
Posted 01 December 2011 - 02:07 AM
here's an idea.
I see you still have the studs from the old fan on your pulley.
if you use two of the fan nuts locked together, you can remove those studs for some more room.
#64 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 01 December 2011 - 01:20 PM
Good Idea, Thanx!
I Really want to Remove those old stud bolts from the Waterpump's Pulley and install there standard screws, but other idea is to grind them down.
...the studs were shortened because the fan is no longer installed, and I didn’t want big ol’ long studs sticking out, so GD ground them down:
Posted Image...
When I Asked if I could just Swap the Stud Bolts with Standard screws...
You probably could... cant see why not...
They are 6X1.25 IIRC. ... Pretty sure its 6X1.25 bolts... Dont see why they couldnt be replaced...
I really Don't see why not, but I Found that they are 6 X 1.00 Pitch, no 1.25.
The only thing I'm a little bit afraid is about the New Screws' deep size:
Posted Image
Do you believe that if I install 6 X ¾ inch long Screws, will they Hit the Waterpump's back? ... How deep can I install screws there?
#65 El Presidente
El Presidente
    Subaru Fanatic!
  • 428 posts
  • Northgate/Seattle, WA
Posted 01 December 2011 - 02:29 PM
Heres my setup, sorry it took so long:
Closeup of the 3647 hayden fan controller
Posted Image
Little further back, the loose blue wire is for the aux. fan and the green is for the A/C override..both of which I obiously haven't hooked up. You can also see the probe for sensing the temperature in the very bottom, center of the pic, a little silver tube thing with grey wires..Yes I lost my oil filler cap:banghead:
Posted Image
As much clearance as you can get for working on the front of the motor
Posted Image
Because the fan is in front of the radiator
Posted Image
I tried using a EA81 fan on mine, but because I lifted it 6+" it wouldn't fit. The studs for the old fan aren't a problem with no fan there!
#66 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 01 December 2011 - 03:08 PM
Thank you for posting the Pictures. :)
I Can't put the Fan in front (to Push air) of the Radiator, because my BumbleBeast has a Working A/C, so there's the Condenser; I need to put it inside. (to pull Air)
Also, I see that you Hooked the Return Spring for the Weber Carb directly to the Radiator's frame; I hooked mine to the Power Steering's Metallic line, just to the Left of the connection nipple.
Well, back to Topic: you're using an independent Thermoswitch and Wiring, isn't it?
Your Setup Looks Good and simple, I like it!
Kind Regards.
#67 El Presidente
El Presidente
    Subaru Fanatic!
  • 428 posts
Posted 01 December 2011 - 03:24 PM
Yes the hayden thermo switch isn't tied to the old 203F switch at all. Its its own unit. The fan I used is small enough, I really think I could have got it in there with the condenser.
Yeah the spring is a little half-rump roast, but it works. I put it on whatever I could to get the tension I wanted, I like a stiff gas pedal. I'll figure something out permanent later.
Thanks! Your BumbleBeast is a pretty sweet ride, especially after that 2" lift!
Josh
#68 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 01 December 2011 - 05:24 PM
You can just cut the existing studs and chamfer the ends so the nuts will start easily. That's what I did in the picture that Stuart posted. I was installing a new WP and it came with studs. So I simply shortened them as needed. Cut with a hacksaw or band-saw, etc and then chamfer on a belt sander, etc.
If you want to use bolts - I would get a 6 x 1.0 x 10mm (that's 10mm thread length). That should be sufficient to anchor the pulley and not interfere with anything behind the WP.
The fan that we used on Stuart's Loyale is from an EA81 with air conditioning.
Edited by GeneralDisorder, 01 December 2011 - 05:39 PM.
#69 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 01 December 2011 - 05:35 PM
...If you want to use bolts - I would get a 6 x 1.0 x 10mm (that's 10mm thread length). That should be sufficient to anchor the pulley and not interfere with anything behind the WP.
Thank you GD, I'll get four brand new 6X 10mm Bolts, plus four pressure washers.
Kind Regards. :burnout:
#70 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 01 December 2011 - 05:37 PM
... Your BumbleBeast is a pretty sweet ride, especially after that 2" lift!
Josh
Thank you Josh, I Really appreciate your Kind Words.
Kind Regards.
#71 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 4,834 posts
  • Roatán, Honduras.
Posted 06 February 2012 - 10:14 PM
Solved!
I Wrapped the Guide of Procedures and Pictures in a Complete Writeup, which can be found ~► Here.
Kind Regards.
