swap 1998 2.2 engine into 1998 outback
6 replies to this topic
#1 elcat
elcat
    New User
  • Pip
  • 3 posts
  • champaign
Posted 03 December 2011 - 01:40 AM
i love my 1998 Subaru Legacy L Wagon which needs major body work after an accident. I have found an 1998 Outback for $800 (2.5L engine) with a blown head gasket. Is the 2.2 swap to an Outback doable? (I am not a mechanic and on a really tight budget. Just need to either keep my car on the road or stay in a comparable Subaru. The Legacy wagon was the best car I have had.)
Also what is a ball park figure for installing an engine into a car ?
thanks!
#2 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
  • Pittsburgh suburbs (NE)
Posted 03 December 2011 - 09:00 AM
Rather easy actually.
You will need the Y pipe from the new engine (the 2.5 had a dual port exhaust and the 2.2 I believe will have a single port exhaust).
Search aroubd here - a very common swap.
New timing belt, seal baffle plate, most of us would do atleast timing belt idlers and probably seals while it's out. You do the major maintenance and the engine should be good for another 100k.
#3 elcat
elcat
    New User
  • Pip
  • 3 posts
  • champaign
Posted 03 December 2011 - 09:46 AM
thank you!
I live in Champaign, IL. I will update my profile now.
#4 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
Posted 03 December 2011 - 09:54 AM
Appreciated.
And you never know a member here may be close and be able to help you out or point you to someone local who has done this before.
It takes less than a day. All the electronics plug right in. Only thing you'll be missing is a place to bolt the PS lines to on the passenger side of the engine at the intake.
I am assuming both engines have EGR which is a pretty safe bet. The 2,5 for sure has it - look on back of engine towards drivers firewall for a hocky puck looking thing with green writing on the top. Make sure the 2.2 has it too and you're golden. Odds are very high that a 98 2.2 has this.
If the 2.2 does not have this you will never be able ot get the CEL out - which means it won' tpass emissions if you need them.
#5 porcupine73
porcupine73
    Obligate carnivore
  • 5,201 posts
  • Buffalo, NY
Posted 03 December 2011 - 10:09 AM
Posted Image
#6 davebugs
davebugs
    I don't "friend"
  • 3,123 posts
Posted 03 December 2011 - 12:32 PM
Yep - nice pic.
The little hockey puck thing with the green and white sticker I believe is hte vacuum for the EGR. The engine will either have both pieces or neither.
You need it to have them.
#7 elcat
elcat
    New User
  • Pip
  • 3 posts
  • champaign
Posted 03 December 2011 - 06:07 PM
Thanks very much for the helpful information and photo! The Outback owner has not gotten back to me. I hope I can get that shell, another shell or a decent used Subaru i can afford.
