6" EA81 Lift Block Specs
3 replies to this topic
#1 Resortx
Resortx
    USMB Regular
  • PipPipPip
  • 34 posts
  • Spokane, Washington
Posted 09 December 2011 - 06:50 PM
Alright guys... So I was wondering if anyone had specs for lift blocks. I am planning to do 2x2x6 Blocks and just tie them all together with 1x2 or 2x2 Tube. Also planning on boxing them all in too.
Ive been checking out the forums searching for exact specs to drill the holes for the blocks but I can not find anything. Should I just drill them all right in the center? As well what are the od dimensions for the strut tower pipe? I have 5 1/2 inch od pipe to use. Too big? could you use square tube or no? And its a 22 degree angle cut right? Cut it like /=/ or like this /=\? As well I need the specs for the plates that go in between and the dimensions. It would go alot quicker to cut everything at once. I have access to a full machine shop and don't have a whole lot of cash otherwise id just buy a sjr lift. I have a 1/4 inch thick and 5.5 od pipe i was going to use for the struts.
Sorry for all the questions I just really want to get my soob lifted asap.
Edited by Resortx, 09 December 2011 - 09:02 PM.
#2 sifu
sifu
    USMB Regular
  • PipPipPip
  • 73 posts
  • Tempe
Posted 09 December 2011 - 08:16 PM
right there with you. If anyone can do this for a outback sport, I'd be willing to pay for time.
#3 greentowtruck
greentowtruck
    New User
  • PipPip
  • 21 posts
  • Burlington
Posted 11 December 2011 - 01:19 AM
strut blocks get cut like this /=/ when mounted should pull the top of the strut in towards the engine bay. I am using 4" pipe on mine (about 4.25 OD) I think 5.5 would be too big and end up right on the strut bolts the 4.25 barely leaves enough room from what I can see. there are others with more experience but from what I have done too mine so far I don't think anything bigger than 4" schedule 40 pipe would work. I am not sure on the angle for an ea81 but it was about 15 for my ea82 86 wagon here is my thread also my first subaru build so I will probably change things along the way
http://www.ultimates...ad.php?t=128472
Edited by greentowtruck, 11 December 2011 - 01:30 AM.
#4 El Presidente
El Presidente
    Subaru Fanatic!
  • 617 posts
  • Northgate/Seattle, WA
Posted 21 December 2011 - 01:51 AM
22 degrees is for an EA71
14 degrees is for a EA81
4" pipe is used for EA82 lifts and I don't think its as critical on EA81's because they mount differently. The strut blocks are the hardest part and shouldn't be rushed, if you screw this up your rig can have bad driving characteristics and possibly eat tires. Take your time and do your homework before cutting your material up.
greentowtruck, On EA82's 15 degrees might give you a harsh positive chamber, but 17 degrees will give you zero chamber. I cut mine to 18 degrees to give it a little negative chamber and now it handles better than stock, even without a swaybar. Heres a thread on chamber angles and strut lift angles:
http://ultimatesubar...ad.php?t=115780
